Toyo Tyres
Pal318is
Post Thu Jul 05, 2012 7:13 pm
Hi is there any real difference between the Toyo T1's and the T1R's? I currently run 225/40 R16 T1R's, but need a tyre and have seen a T1 available.
Pal
Image[img]http://Image
zaust
Zone day release
Post Thu Jul 05, 2012 8:34 pm
I'm getting the same fitted to my rears next week. Had good feedback from people who use them already too. There cheap enough to give a try.
M30 Tech 1 Touring on gas.
FinalD
Post Fri Jul 06, 2012 9:35 am
I don't know what they are like on the E30 but I found the Proxes T1R to be utter, utter garbage on my Mondeo. I am replacing them with Conti CS2s (would get CS3 but not available in my size).
I used to run Goodyear Eagle F1s on my E36s and they were very grippy in the wet and dry but were rubbish in the snow, once directional tread fills with snow you're basically driving on slicks, which isn't too fun.
Personally, when I put new rubber on the E30 I'll be going for the best possible tyres around £100-£130 a corner...which will most certainly not be the Toyo Proxes.
staley_turbo
Post Fri Jul 06, 2012 9:39 am
Toyos are VERY good for the money. They dont make the T1s any more they replaced it with the T1r.
Eagle F1s are also good for around the same price, I Found F1s better in the dry, T1rs better in the wet.
Id use T1rs on every car.
yamoda
Post Fri Jul 06, 2012 9:42 am
Got them on a 1 series, an e34 and a little Peugeot 206 van and they work very well on the lighter cars but not so well on the e34, not a disaster but not as well on the other 2.
FinalD
Post Fri Jul 06, 2012 9:51 am
staley_turbo wrote:Toyos are VERY good for the money. They dont make the T1s any more they replaced it with the T1r.
and
yamoda wrote:Got them on a 1 series, an e34 and a little Peugeot 206 van and they work very well on the lighter cars but not so well on the e34, not a disaster but not as well on the other 2.
Interesting to see that as a few friends have MX-5s which on the forums people rave about the T1R (as with here it seems) but all my friends that have tried them found them to be very poor compared to the competition and wouldn't use them again.
My E30 cab is the same weight as my Mk3 Mondeo (c.1390kg) and due to finding them poor on the Mondeo I can't see why I'd try them on the E30. It may be due to the FWD factor that they didn't grip well in the wet. I would expect a tyre to be able to allow me to pull away up a hill with sensible throttle input (ie, not nailing it) inj the wet without spinning up. Yet the T1Rs always spun up, they also never inspired confidence when braking but the Contis feel much better under both situations.
harry_p
Post Fri Jul 06, 2012 10:02 am
i really like t1-r on pretty much everything i've tried them on. great allround and performance / £ ratio.
not great on track though as they overheat and melt too easily.
currently have t1-r all round on my e36 m3 and don't struggle for traction in the wet (unless im being an idiot )
tried the t1-sport, supposed to replace the t1-r and really didnt like them. wore quickly and seemed to tramline badly over ruts in the road, so went back to Rs.
the old t1-s was great on light hatchbacks, but too soft for anything heavier. on cars they worked on they were brilliant, but the t1-r was a better allrounder.
cheers,
harry
Post Fri Jul 06, 2012 10:11 am
and
1st off, a mondeo needs all the help it can get in the wet, has to be one of my all time hated cars for poor suspension and steering, a world away from E30's!
Conti sport are also on average 50% more expensive than T1R's
I have only ever used T1R's on my E30's because they are (or should I say WERE) reasonably priced and work perfectly in most road conditions for what I wanted, when compared with similar priced tyres they have always been much better even though they do wear quickly.
The only time I have had poor performance from T1R's on an E30 was on a track day when they couldnt cope with the heat, but this is also irrelevant as you dont buy them for track driving :D
staley_turbo
Post Fri Jul 06, 2012 10:13 am
This is the main point. Toyos are great for the money.
zaust
Zone day release
Post Fri Jul 06, 2012 10:38 am
I use eagle f1's on my front and normally run Michelin on the rear. My tyre man recomended them as he is using on his 335 e92 and at 70 a pop I'm gonna give them a go. Will let you know the out come.
FinalD
Post Fri Jul 06, 2012 10:43 am
DanThe wrote: 1st off, a mondeo needs all the help it can get in the wet, has to be one of my all time hated cars for poor suspension and steering, a world away from E30's!
Impressive given it is basically the best handling car in it's class as reported by many, many people (normal people and proper car reviewers too). It will always be very different from an E30 though, given the fact it is FF and the E30 is FR. I'm not trying to argue the Mondeo is better as I dislike it compared to RWD and BMWs and no doubt different to an E30. It is far from bad though.
The point is/was more just a case of having tried the tyres on that, they don't inspire much confidence at all, whereas spending £20 more a corner gives loads more confidence. As I've had backed up by friends with other FR cars (MX-5s and some others).
The T1R is actually a favoured tyre of Mk3 Mondeo owners forums too by the way.
DanThe wrote: Conti sport are also on average 50% more expensive than T1R's
50% more? I'm not great at maths but £20 is not 50% of £85. Granted for the E30 in 205/55 R16 fitment Contis are £105 which for a lot of people is 'omg expensive'.
For the money, to me, they just didn't live up to the hype that they have been given. I was expecting the car to grip in the wet and the dry and for them to last many miles as this is what is reported by users of them. I found the grip to be poor and the life to be poor too (had them a year, 6 months on each end of the car and they are on the wear markers).
There isn't much below the cost of the T1Rs I would touch (on the E30) mind as things like LingLong and Triangle just scare me. I would still rather pay that little bit more (£20 or so) for some tyres that grip more.
You have to remember that they are your only contact patch with the road and so you shouldn't skimp on tyres, ever.
Fushion_Julz
Post Fri Jul 06, 2012 11:14 am
I rate T1Rs, too...I've used them on an E30 (325) and on my E36 (328) and also on an E34 (525ix)...superb, especially for the price, in the dry and the wet, ok if very wet (standing water) and, like most "summer" tyres, rubbish in snow.
However, the price went up enough so that when I needed new rubber last year I decided to try Hankook Ventus V12 Evo on my E36....
The big surprise was how quiet they are compared to the Toyos...Not much to choose between them in the dry, the Hankooks are better in the wet, perhaps a little less good in standing water and I haven't got to try them in snow, yet...
Wear appears to be a bit better than T1Rs, so far (8K miles)...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Post Fri Jul 06, 2012 1:15 pm
Dont believe these professional reviews
You will soon be driving around in a mondeo and shopping at Asda with your Barclays 0.00001% credit card wondering where all your money went :)
FinalD
Post Fri Jul 06, 2012 1:51 pm
This was the table at my BBQ last week, I don't see ASDA happening any time soon. :wink:
Some bottles are missing from the pic too as I picked up a couple more later on.
I'm not sure quite where you were trying to go with that comment though if I'm honest. :?
MattTheHat325
Post Fri Jul 06, 2012 1:53 pm
My 325i wears proxes all round and is very sure footed, even in the wet. Coupled with standard power, b8's and a light FR car, makes for a rear wheel drive car which you can really press on through a series of bends using power in places that wanli's would turn to plastic and make you crash! I love b-roading in my e30 :-)
Post Fri Jul 06, 2012 2:05 pm
FinalD wrote:This was the table at my BBQ last week
Wife swapping party? :D
staley_turbo
Post Fri Jul 06, 2012 3:04 pm
:mad:
FinalD
Post Fri Jul 06, 2012 3:32 pm
Want an invite for next time? :wink:
Seriously though, no it wasn't, just a normal BBQ I host. :)
HairyScreech
Post Fri Jul 06, 2012 3:54 pm
Possibly a totally useless comment here but i have been running Maxxis ma-z4 (went for the z4 as it was heading to winter at the time.) for about a year now, so far i mixed conditions they have been great, not the ultimate in grip but provide a lot more than other types at the price range and let go very progressively letting you take much bigger liberties with the car. The maxxis range is seriously underrated in the country.
e30den
Post Fri Jul 06, 2012 6:29 pm
HairyScreech wrote:Possibly a totally useless comment here but i have been running Maxxis ma-z4 (went for the z4 as it was heading to winter at the time.) for about a year now, so far i mixed conditions they have been great, not the ultimate in grip but provide a lot more than other types at the price range and let go very progressively letting you take much bigger liberties with the car. The maxxis range is seriously underrated in the country.
People are put off the maxxis range due to the brand being unknown, yet they are
a decent tyre and not made from old flip flops.
Pal318is
Post Fri Jul 06, 2012 8:14 pm
Tbh I would have bought the T1-R, but at the current price and the fact I've been off work ill for almost a year, it just don't add up unfortunately :cry: although from my experience the T1-R's are fantastic tyres and they have worn very well too, bearing in mind the 40mm drop.. I've had them on for the best part of 3+ years.
I got the T1 for £30 and it's brand new too :P earner :cool:
Pal
e30den
Post Fri Jul 06, 2012 8:34 pm
What are you looking for when making a tyre choice ? and what sort of life is the tyre gonna have ?
so toyos are good tyres but there are plenty that fly under radar that are just as good for similar money or less.
Gavla
Post Sat Jul 07, 2012 8:41 am
http://www.camskill.co.uk/m53b0s289p167 ... R15_88V_TL_
Thought I would put this up FYI. I am fitting these all round next week. A decent tyre that looks great at £60, can't go wrong really. :D
zaust
Zone day release
Post Mon Jul 30, 2012 6:28 pm
Well so far I'm very impressed. I'm still running in but can still give them stick on the b roads.
appletree
Post Mon Jul 30, 2012 6:53 pm
Are these the new T1sport your talking about or a new T1R as i went and bought 2 new toyo T1sport tyres for the GF's mondeo estate the other week from dexel tyres as they had a promotion on as they were a new tyre. i've had them on a few weeks now and there a lot betteer than the crap that was on before, although, they do seam to tram line slightly more than they used to although they are on 18" titanium x wheels.
http://www.tyrereviews.co.uk/Tyre/Toyo/ ... -Sport.htm
Matt
pnd
Post Mon Jul 30, 2012 7:03 pm
i have had them and they are ok but the vredstein sportrac 3's i have now are way better.
zaust
Zone day release
Post Mon Jul 30, 2012 8:27 pm
T1R proxy. nice and grippy.
BEERBOY123
Post Wed Aug 01, 2012 6:03 pm
Uniroyal Rainmaster for the win... Normally well over £100 a corner, but you can get better deals.
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
jonny323i
Post Wed Aug 01, 2012 6:24 pm
iv used uniroyal rainsport and they were excellent id buy them again.
If moneys no object id go with good year eagles but im just about to order some tyres from a local supplier and going for falken 912s i had similar from falken before and was happy with grip and wear and for 205/40/17 they are only £49.95 each bargain and they ahve better reviews across the net than t1s
Touring for life
harry_p
Post Wed Aug 01, 2012 7:20 pm
912s are the only tyre I've bought in the last 10 years which I couldn't wait to get rid of.
Utter garbage, bordering on dangerous in the wet.
Thankfully a trackday saw the blister and the tread start to peel from the carcass which gave me an excuse to throw them away.
cheers,
harry
Topblag
Post Wed Aug 01, 2012 7:47 pm
I can't think of any bbq where you have to put your car keys, wallet and watch on a table in the garden.
Next time you have one, put a packet/tin of Custard on the table and post the pic up. Then I'll believe you.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
zaust
Zone day release
Post Wed Aug 01, 2012 7:56 pm
I had the 912's on the rear and they are utter rubbish. As soon as they got hot they went off. Pop in the wet and only got 2k out them. I'm after grip for the rear so as I can't locate the Michelin in my size any more the proxys look like the best option.
jonny323i
Post Wed Aug 01, 2012 9:38 pm
i can feel a change in my order coming on lol
Touring for life
HairyScreech
Post Thu Aug 02, 2012 3:10 am
what about the top of the line maxxis marc? the aussies have a lot of good things to say about them on the back of comadores and falcons.
Barx325i
Post Thu Aug 02, 2012 4:24 am
t1-r's are superb - the original t1-s's were excellent & I was disappointed when they were discontinued and had to buy r's.. I also rate a539's, they were hard wearing for yokahama's & very good in the dry, nice & progressive in the wet, but I can't offer any comparison against r's
