I have fitted an M42 engine into my L reg 318i touring, keeping the original M40 manual box and diff setup. The diff is a bit of a howler, so i will be looking for a replacement soon and am wondering what ratio to use.
I actually quite like the gearing as it is, i can hit the rev limiter in all 5 gears (on private roads of course), but cruising is a noisy experience, 3750rpm @ 80mph.
What diff could i use to get better criuising rpm, but not loose out too much on acceleration?
Alternative diff to use with 318is M42?
78gizmo
MrWhite
I had a 4.10 on mine until last week. That is the normal ratio for the iS and it works very well but I found it a little revvy for the motorway. I've just fitted a 3.91 and it makes a noticeable difference to motorway runs but hasn't taken anything away from the B road enjoyment. 3rd gear can be held for even longer now... which is nice.
rust never sleeps
78gizmo
Thanks, sounds like what i need.
Has anyone else put a different diff in their 318is?
johnl320
I also put a 3.91 in my IS and would go any lower.
DHFiS
Even with a 3.91 diff you will still be running 3550rpm at 80mph.
johnl320
Would'NT , that was meant to say. A 3.64 would be too much for the poor little 4 pot to cope with I'd imagine. 3.73 maybe?johnl320 wrote:I also put a 3.91 in my IS and would go any lower.
DHFiS
So what speed are you reaching in top?78gizmo wrote: i can hit the rev limiter in all 5 gears (on private roads of course)
johnl320
6000 rpm rev limit with a 4.27 diff from a touring is still going to see 123mph, You sure you are hitting the rev limiter in 5th? I took my e30 to that speed and it would start shedding gutter trim and centre caps
78gizmo
An "INDICATED" 140mph. Its got lower profile tyres than standard, so the speedo is certainly over reading, but i was surprised my secondhand M42 could do it even so.DHFiS wrote:So what speed are you reaching in top?78gizmo wrote: i can hit the rev limiter in all 5 gears (on private roads of course)
Will have to do it again with a sat nav giving GPS speed to see what its actually doing (and a mate to get a pic.) And yes the gutter trims stayed on! I have had them fold in half and depart at much lower speeds on previous E30's. The remining 2 bbs centre caps that i hadn't already lost were flogged on ebay some time ago....
