Any 1 using a quick shifter
imye30
Is it easy to install an r they any good to use Cheers
ross_jsy
What quick shifter?
z3 shifter is a pleasure to use, just make sure you get the right one. Drove a car which had the quickest ratio and it felt horrible.
Then you have something like the AKG style one:
http://www.akgmotorsport.com/catalog/vi ... S230lg.jpg
For the road it really won't be worth it and you will more than likely start wearing synchro's out far faster than normal.
Grrrmachine
- E30 Zone Wiki / Team Member
polsta
the proper z3 short shift, took my mate 10/15 mins to install, was great in my 318is to drive with,it feels fantastic to change gear with
in my 325 its got all new gear linkage etc and that also feels great, so im sticking with that, and id say actualy allows for faster pulling away if you wished
Green
I'm using the shifter from an e36 328 which I believe is the same as the Z3, nice short through and quick through the gears. Easy to install but then again I did it when the box was out of the car.
Silverfang
Z3 1.9 shifter here, did the conversion on a friend's E36 after he felt mine. takes about 30 mins to fit or so, and makes a huge difference.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
cro320
Z4 2.5 here
amazing amazing transformation
