electrical advice if youd be so kind.
verde
Post Mon Jun 25, 2012 9:36 pm
my cars thirst for new parts is insatiable, just put new back brakes, pipes and nipples, everything, new brake fluid. it repays me by slowly beginning to leak water...i presume its the water pump and not what i need help with
what i do need help with is the speedo, rev counter and the interior lights ( headliner lights ) have died. just randomly given up the ghost and i dont know what to do. iv tried swapping fuses, is there a relay or something that might have blown?
my cars MOT is due fairly soon and itl pass on everything bar this speedo problem
Raise hell praise Dale.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jun 25, 2012 9:43 pm
If they all went at the same time, I'd look at the interior earthing points, since they don't share any common wiring AFAIK.
Ground point G200, which serves the instruments and lights among other things, is above the glove box.
verde
Post Mon Jun 25, 2012 9:54 pm
thing is i dont think they did go at the same time, well. maybe they did, must just not have noticed
il check that out, i dont need to remove the dash board do i? i just removed one to sell to jay and it was a god aweful job i hope to never do again
Post Mon Jun 25, 2012 10:02 pm
I'd check fuse 21 VERY carefully.
It won't fail an MOT test on the speedo not working, because its operation is not a testable item.
The speedo is only required to be present, to be intact, and to light up at night. It doesn't actually have to work!
verde
Post Mon Jun 25, 2012 10:06 pm
haha wow that really is a silly rule
if it was 3 or 4 months ago i probably wouldnt have bothered getting it going but iv sorta become a little more sensible in that time and want to make sure my dials work correctly. il give fuse 21 a looking at. infact i took a picture of my fuse box the other day ( theres a few missing which worries me slightly ) il upload it
verde
Post Mon Jun 25, 2012 10:27 pm
this is my fuse box. really kinda worrying theres gaps, is anybody able to sorta give me an idea of what should be where? or is this normal?
Green
Post Mon Jun 25, 2012 10:33 pm
One's for electric fan so not needed, can't remember the others but not needed if they're empty (If you don't have fog lights that'd be one of them.)
If the fuse is intact, then perhaps consider the battery in the clocks has leaked and ruined the electrics inside it in which case it'll need replacing. Think it could also be down to the sender in the diff failing or the cable coming out perhaps? You said you're unsure if they went at the same time so it could well be two separate problems.
verde
Post Mon Jun 25, 2012 10:36 pm
I do have fog lights but theyr fine
Alright il check fuse 21, then il check the bit in the glovebox. Then il get a look at the sender/diff
I hope i dont need to remove the dash/dials
BMW_E30vert
verde
Post Mon Jun 25, 2012 10:37 pm
ok i dont need the electric fan one, but i am missing a fag lighter one which i may need to run an aux stereo cable
fixedwheelnut
Post Mon Jun 25, 2012 10:46 pm
Check the wiring to the diff speed sensor as well, they commonly break where the loomis cable tied to the bodywork just by the diff.
verde
Post Mon Jun 25, 2012 10:54 pm
i take it the diff speed sensor is on the diff? should be a cable going to it? sure my dad will help me out
Post Mon Jun 25, 2012 10:56 pm
Fuse 4 should be 15A. It looks like you have a 5A in there.
Fuse 11 should be 7.5A.
Fuse 28 should be 30A.
All the empty positions should be empty, as should be 18 and 25, both of which appear to have 7.5A fuses fitted.
Jim320i
E30 Zone News / COTM Team
Post Mon Jun 25, 2012 10:59 pm
Plugs into the back of the diff, then up over the rear beam and over the fuel tank, comes through under the rear bench and plugs into the loom. I'm sure it also has the fuel sender/pump plug attached too and another plug in.
If you find its damaged, I may have one available in good condition, but will need pulling off the car first.
Although, I have afeeling your problem will lie elsewhere
verde
Post Mon Jun 25, 2012 11:04 pm
Man the boy i bought the car off has had like 20 e30s he should know where the fuckin fuses go, me neither my dad has fiddled with any of them. I really appreciate that brian thank you, il fix it tomorrow and give it a try.
Il get a look at that diff connection aswell jim, if its damaged il get a PM sent your way, no rush in getting it off if its needed, the car probably wont be driven for another few weeks yet.
Post Mon Jun 25, 2012 11:15 pm
Brianmoooore wrote:I'd check fuse 21 VERY carefully.
exactly this.
you can have a none functioning speedo but not a worn/split brake pedal rubber ,
crazy :mad:
verde
Post Mon Jun 25, 2012 11:26 pm
i can see why brake pedal wear or damage would fail u, foot may slip or not brake but...surely the speedo should aswell. really appreciate all the advice, my cars slowly coming together
aimlessrock
Post Tue Jun 26, 2012 1:34 pm
Verde,
much like you i was faced with a number of electrical bugs and gremlins on my e30 resto, so much so that i invested in a days worth of time with an auto electrician who did a full report on the car. I then worked through the list and had it re-tested and everything now works properly and as it should. The costs was only a £100 or so and worth it for peace of mind as he discovered all manner of bodgery!
cheers
Gary
E30 320i Convertible (1989)
190 Mercedes (1988)
verde
Post Tue Jun 26, 2012 2:17 pm
Ahh. Who did you use to do this Gary? Sounds like this may be a possibilty if the fuses and the simple things arnt to blame. My mechanical knowledge is growing and my dads really good ( hes more spanner and tools not electrics and mainly on motorbikes ) so when it comes to electrics wer not the best.
verde
Post Tue Jun 26, 2012 3:03 pm
[youtube][/youtube]
thanks grr for the fuse diagram and to brian for suggesting fuse 21
verde
Post Tue Jun 26, 2012 3:14 pm
The interior light on the drivers side also works now, the one on the passenger side however doesnt, could this be a blown bulb or is there another common cause for this?
Post Tue Jun 26, 2012 3:26 pm
Does it work on the switch on the light?
The mechanism of the switch is a bit crude, as you will see if you remove the light. Sometimes the blade doesn't quite contact the bulb, or it could be just a failed bulb as you suggest.
verde
Post Tue Jun 26, 2012 3:57 pm
Na it just doesnt work at all by the looks. Are the bulbs easy to find? Has anyone got a bulb I could buy?
