what alarm would you recommend? i know there are loads of clifford versions but i want to know which one does the job without going OTT
what about a tracker? how long does it take before they give you a location or will it be in parts by then? is it like a missing person where you have to wait 24hrs before you can file a missing car report lol
or install a simple car alarm and install a hidden kill switch?
best car alarm??
General points: An alarm without its own power supply, independent of the car's battery is close to useless against any half serious potential thief.
It is impossible to connect an immobiliser to an E30 in such a way that will defeat anyone that knows what they are doing. Every single immobiliser that I've ever seen connected to an E30, without exception, has been connected in such a way that is extremely easy to defeat.
Morat
And judging by our statistically accurate sampling methods (loads of threads on the zone) clifford are pants.
I have a Toad C101 which came on the car. It's a pain that I don't have the code to add more fobs, and it does autolock 60s after you leave the car - but it has never malfunctioned or false alarmed in my 4 years of ownership.
However, bearing in mind Brian's comments above I just regard it as a handy remote central locking device. If I was going to park in a dodgy area I'd be looking at steering wheel locks etc.
Jos
Toad C101 here also, same issue as it came with the car but it's never missed a beat. Happier with the EWS there as-well (not that anyone would steal it anyway lol)
'94 e36 tree climber
kangman
if i fit a kill switch it may prevent a thieving c*nt starting my car but it wont stop them giving it a go. I dont want to come back to my motor where some1 has smashed my lock or window and ripped apart my ignition.
I want my alarm to help prevent that from happening so maybe an alarm that chirps if people come near also it may stop haters keying the car which scares me the most because you can never get a perfect colour match if you repair it.
My mates e30 got vandalised at Stockley park gym some one put small dents in it with half a brick and then left the brick on his bonnet.
I hate non-manufacturer fitted alarms with a passion.
If I buy a car with one fitted the first thing I do is rip it out as whoever has installed it 9 times out of 10 will have butchered the loom with scotchlocks
They are expensive and no one pays any attention to them. If someone wants to break into your car an alarm wont stop them.
A hidden kill switch is the way to go.
sweep
And a disc lock^^^^
Andyboy
- Alpina Colada
Plus a simple relay connecting the door switches to the horn. After 10 seconds the horn will go off (unless you've switched it off within 10 secs). Most thieves who are any good will be looking for an alarm box which isn't there.
mcbonio
I've got a cobra alarm, pretty good.! Can't fault it.
Apart from the fact that it can be defeated in around ten seconds, and in those ten seconds, no one will take the slightest bit of notice of it.mcbonio wrote:I've got a cobra alarm, pretty good.! Can't fault it.
Bristol_Jer
I've just got a Disklok on mine, and don't park it anywhere dodgy.
My personal opinion is that a visual deterent, decent steering lock and flashing LED, is the best way to go as hopefully it will make an opportunist go onto another car, but if someone really wants to take the car then they will, regardless of any security.
