OBC retrofit
dooce
Does anyone have a complete list of what is required to retrofit the 13 button OBC? I keep reading about a stalk, does this replace one of the stalks or is it a third stalk? Is there a special harness required, or is everything already there?
Grrrmachine
- E30 Zone Wiki / Team Member
dooce
Where is the gong normally located?
Fits in the panel above the driver's knees. you can see the pre marked place if you look at the top surface of it.dooce wrote:Where is the gong normally located?
