how much you reckon an entire rear panel would cost
e30mtech
Post Wed Jun 20, 2012 6:58 pm
as above from where the boot closes all the way down to the bottom of the valance?
e30mtech
Post Wed Jun 20, 2012 7:03 pm
just looking for guesses and estimates as i have an answer just wanna know if it good price
BATTS91
Post Wed Jun 20, 2012 7:05 pm
bmw only and about £280 if i remember right , but i could be wrong.
There not cheap tho
adit
Post Wed Jun 20, 2012 7:12 pm
[quote="bss325i"]
e30mtech
Post Wed Jun 20, 2012 7:14 pm
well i was goin for a new rear valance but found an entire rear panel for £82.12 inc vat seemed good
http://www.autopanels-castleford.co.uk/ ... %20E30.htm
adit
Post Wed Jun 20, 2012 7:15 pm
Polsta bought one for his Sport, from the dealers, £147
http://www.e30zone.net/modules.php?name ... &start=375
[quote="bss325i"]
e30mtech
Post Wed Jun 20, 2012 7:25 pm
any idea what its like fitting a rear panel
Green
Post Wed Jun 20, 2012 7:40 pm
I'd guess its like cutting and old panel out and welding a new one in! Couple of hours work .there at least
e30mtech
Post Wed Jun 20, 2012 7:55 pm
Green wrote:I'd guess its like cutting and old panel out and welding a new one in! Couple of hours work .there at least
an i thought it be more like painting a picture and knitting
:mad:
adit
Post Wed Jun 20, 2012 7:58 pm
as Green says. easy work for any competent bodywork man (or woman, naturally)
[quote="bss325i"]
e30mtech
Post Wed Jun 20, 2012 8:16 pm
so no tough stuff something i could do myself then?
pretty handy with a welder and mechanically
plus a tight wad lol
adit
Post Wed Jun 20, 2012 9:18 pm
e30mtech wrote:so no tough stuff something i could do myself then?
probably, in that case. just make sure you cut the old one out carefully (with the excess on the inside edges - not too wide for the replacement panel obv)
tight wad? on here? :eek: never!
it's not called E30pennilessloserzone for nothing you know :teehee:
[quote="bss325i"]
Andy325i
Post Wed Jun 20, 2012 9:53 pm
I think I paid about £160 for the first one from BMW
Do yourself a favour, fit a genuine one and be done
Andy
Das_BMW_E30
Post Sat Jun 23, 2012 9:36 pm
Post Sat Jun 23, 2012 11:25 pm
That's for a facelift car. :cool:
cecotto479
Caution Unreliable Seller
Post Sat Jun 23, 2012 11:38 pm
It's also brazed not welded - down the vertical seams anyway.
1981 E23 735i
polsta
Post Sun Jun 24, 2012 11:52 am
cecotto479 wrote:It's also brazed not welded - down the vertical seams anyway.
and as above, make sure you braze it in, get it done properly
for the sake of the difference youd be a fool not to buy a genuine one really, had mine done recently and its nice to have it all like new
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jun 24, 2012 12:07 pm
What's the benefit of brazing over welding?
I ask because my rear panel was rusting exactly on that seam, and I cut out and let in some small patches with mig welding; no braze. And it seams rust on those joints is very common:
polsta
Post Sun Jun 24, 2012 12:38 pm
i have no idea, id be interested to know
but maybe weather weld or braze on the joins after 20/25 years they would both rust the same anyway ?
kitch
Post Sun Jun 24, 2012 2:18 pm
I was talking to a welder about this when he did my scuttle. Aparently brazing is easier. It can just be whizzed over to smooth it off, rather than having to grind down welds etc, before prepping for paint.
polsta
Post Sun Jun 24, 2012 11:37 pm
from what i gathered brazing was harder/ or just a more old school skill, as some welders i spoke to couldnt do it
Green
Post Mon Jun 25, 2012 1:34 am
Brazing doesn't use as much heat as welding therefore less panel distortion around the join.
Where it is still a strong method of attaching a panel onto a car, it could also have something to do with it's crash design so for example, it breaks the brazing and leaves the rear quarters more intact whereas a good weld would likely cause more damage upon impact by pulling the area of the joins inwards.
Grrrmachine
Post Mon Jun 25, 2012 7:28 am
I was looking for this thread a week ago, and it just popped up in another thread on here:
http://retrorides.proboards.com/index.c ... read=88328
It's for an E12, but it shows what's involved with removing a rear panel.
Green
Post Mon Jun 25, 2012 4:44 pm
That's an amazing read that thread, really was worth the look!
maf260
Post Mon Jun 25, 2012 4:52 pm
The famous handiwork of tonybmw - legendary bodywork skills and a master of invisible repairs.
