Alarm
Razza
Post Wed Nov 16, 2005 12:08 am
Got the standard factory alarm but disconnected it when my solenoid packed in. Went to Autoglass and they said they could make up a new solenoid easy but I'd need the alarm code number - said that it should be with the paperwork / service history but I can't find it anywhere.
Any ideas where I might get this from, can you contact the dealer with engine number etc to get a replacement code?
Razza
Post Wed Nov 30, 2005 9:13 pm
Bump
Someone must be able to help - Please :cry:
Post Wed Nov 30, 2005 10:42 pm
No one's answered 'cause your OP doesn't make sense. Solenoid?
Post Wed Nov 30, 2005 10:45 pm
Don't know for sure, but I would expect the dealer to be able to help if you turn up with the VIN and proof of ownership.
Razza
Post Thu Dec 01, 2005 12:35 am
Solenoid = the wee box you attach to your keys and click to open and lock the doors.... :?
Alarm fob thingy.... :? :cry:
Post Thu Dec 01, 2005 9:15 am
Razza wrote:Solenoid = the wee box you attach to your keys and click to open and lock the doors.... :?
Only solenoids you will find in your car, mate, are attached to the door locks or sitting on top the starter motor.
Try the dealer for a new genuine key fob transmitter. You'll be pleasantly suprised by dealer prices from time to time.
ajay31
Post Fri Dec 02, 2005 8:41 pm
needs to go back to the original dealerships records if you cannot find manufacturer on box i.e. scorpion, laserline etc.
records only normally kept for about 8 years so expect lots of huffing and puffing.
failing that take the old one off and replace with a more up to date jobbie that is the easiest option if you can follow diagrams and understand wiring.
