Engine change problems
george101
Post Mon Jun 04, 2012 11:16 pm
So I've started my engine change got the new engine in. I've changed the engine loom and ecu. But the plug that plugs into the plug socket next to the fuse box have pins placed in a different way to the plug that I'm attaching it too. Does this matter? the engine is turning over not firing I've got spark as im aware. fuel isn't working yet will I have to manually wire the fuel pump in?
Also the engine change is a
325i from a chromey to a 316 facelift e30
Thanks.
Post Mon Jun 04, 2012 11:41 pm
As long as the 325 loom has the round twenty pin plug, and not the really old rectangular one, then, as far as getting the engine to run, including the fuel pump feed, it should be plug and play.
You will probably have to do some well documented mods. to get the tacho and econometer to work, you should have already checked my 'wiring warning' sticky in the engine swaps forum (although probably not applicable in your case), and might have to do another small mod. if your car has ABS.
