NEED HELP ON THIS RUST ISSUE thanks !
craggsyE30
Post Sun Jun 03, 2012 7:04 pm
basicly this is the only part i cant fix due to being a hole in it so will need welding was wondering if anyone has any sugestions or if anyone could weld i for me and i can pay for it just abit short on cash.
anyone is welcome to look at it heres some pics from what i can seefell it hsnt gont through just surface on the main turret but the hole is where the joint is of the tub of the wheel and turret:
nickso
Post Sun Jun 03, 2012 7:16 pm
I'd say two options.
1. Plate over the top of it for much cheapness and an easy MOT pass.
2. Cut out a bit of a scrapper and weld it in flush for the best looking repair.
I'd go number two but it depends on the value of the turd in question.
'88 e30 328i M52 track bint.
craggsyE30
Post Sun Jun 03, 2012 7:19 pm
well plans were to restore it and use as a day car this is only the main issue if this was sorted its would be fine iv got a mechanic next door to mee a good friend off our body shop so going to see what hes says
nickso
Post Sun Jun 03, 2012 7:21 pm
If its a daily turd I would go cheap repair. Worst that happens is it gets done properly at a later date.
The fact you say you want to "restore" it says to me it's already got a foot on the bridge.
craggsyE30
Post Sun Jun 03, 2012 7:31 pm
its mainly small bits a pieces that need doing rust and dents scratches its mechanicly sound but that is a repair beond my exspeariance this is the only part i need doing that i cant do
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jun 03, 2012 7:38 pm
What you're seeing there is rust coming up from underneath. Because of the design on the turret, there's a strong metal plate underneath the thin sheet metal of the inner wing. Water gets trapped between the two when the seam seal fails in the wheel arch, and it rots out from underneath.
If you plate over it, you're buying MONTHS, not years, since the seam is still broken and every time you drive in the wet you're just flinging more water up at the fresh metal. The ONLY solution is to cut out and weld in fresh metal, like this:
http://www.e30zone.net/modules.php?name ... 26#2241426
If you can get the car to a decent welder, it'll only be a day's work. But plating over it really isn't an option, unless you're going to scrap the turd before its next MOT anyway.
craggsyE30
Post Sun Jun 03, 2012 7:42 pm
right thanks for the advise looks like cut and weld then ill speak to somone about it dont supose theres anyone in the northeast thats a good welder
Kedge
Post Sun Jun 03, 2012 7:43 pm
Looks like a 318iS to me. Regardless of that is need cutting out and a new section welded in. Looks suspiciously like that's already been bodged up before.
Instagram - Kedge85
craggsyE30
Post Sun Jun 03, 2012 7:49 pm
yh it was a right cowboy job like id fel at peace when its fixed its not getting used i have a day car this was a project car i love the car im not going to scrap it want to get it looking nice and all the body work sorted.
harry_p
Post Sun Jun 03, 2012 8:15 pm
I'd either find a friendly local scrappy, or put a wanted ad on here, hopefully someone will be breaking a car and would be able to cut a decent size, rot free chunk out of a donor.
Then you can cut as much out of your car as you need to to get back to good clean metal, and trim the repair piece to match.
cheers,
harry
craggsyE30
Post Sun Jun 03, 2012 8:24 pm
see i dont have any problem as im not relying on the car to get me around idont mind how long it is til it gets fixed but i dont want the rust to spread far so would rather get it sorted this month, a mechanic is next door our garage so ill speak to him to have a look at it and see if he can do it or if not, ill go to a local garage that deals in welding for some quotes.
Grrrmachine
Post Sun Jun 03, 2012 8:26 pm
You don't need a donor to be honest. The way the inner wing folds up to the flitch and lays over the suspension turret (just spot welds), it should be quite a simple job for a panel beater with sheet steel.
You just need to unbolt whatever's there next to the turret (coil packs?) so that you can really assess the level of the rot. There's a horizontal seam not too far below there, and if the rot has reached down to there it makes the repair a bit more complex (but not much).
craggsyE30
Post Sun Jun 03, 2012 8:33 pm
cheers man the main thing that is wurrying me is the cost im only an apprentic but any bodywork i can do but this is too much im not a welder. just sorta panicked when i saw it im 19 not been around cars enough so im abit scatchy with it.
craggsyE30
Post Sun Jun 03, 2012 8:34 pm
i really do appricate the advice and help everyone is giving me cheers i mean if its only that bit wihich need sorting ill pay a few bob to get it spot on
Grrrmachine
Post Sun Jun 03, 2012 9:06 pm
As you can see, the base of the turret is normally slathered with thick seam sealer anyway, and the underneath covered in sealer and stone chip, and most of the rest will be hidden under the coil packs. So it doesn't have to LOOK perfect, it just has to be solid.
Dented steel is infinitely better to polished rust.
craggsyE30
Post Sun Jun 03, 2012 9:41 pm
yh so as long as its fixed but i could not car what it looked like as long as its not rusty ill be happy so basicly just get it fixed. thanks man appreciate it loads
Sanchez
Post Sun Jun 03, 2012 9:42 pm
Ide get it done properly as its structural.
Just goes to show the 318is wasnt galvanised winkeye
craggsyE30
Post Sun Jun 03, 2012 9:50 pm
so form what it is its just better to gert it cut out and welded ,stone chiped etc
Kedge
Post Sun Jun 03, 2012 10:16 pm
craggsyE30 wrote:its just better to gert it cut out and welded
This is the answer to all rust issues really.
Instagram - Kedge85
Duke137
Post Sun Jun 03, 2012 10:18 pm
Having looked at your pic thread mate I would say your car may be a bit of a money pit :(
Those rear arches will be shot in the inside too, you need to check under the boot seal and rear number plate lights, whip the boot carpets out and have a look too.
Almost certainly the front jacking points will be fruity (or bodged previously) and that roof looks like it is trouble. If you feel brave lift out the carpet but I would think you will reveal some nasties...
Don't want to dampen your spirits mate but I speak from experience, the car in my sig was bought with all good intents and purposes but the truth was it was a rotten pear.
I sure hope you find it is saveable and you can do it but just be prepared to be disappointed. I love IS's and I think they are well worth saving 8)
craggsyE30
Post Sun Jun 03, 2012 10:21 pm
yh thanks for the advise ill have a look tomorrow i had a look athe the rear the back looks fine i know it needs work but im willing to do it. ill take the floor carpent out to moz and check the boot too see what its like if its only a few things im not too botherd as long as i can sort the turet ot
Duke137
Post Sun Jun 03, 2012 10:40 pm
Getting the carpet in and out is a royal pain in the arse, will take you all morning if you haven't done it before and your on your own just to get it out lol
When you remove it, you need to obviously carefully remove all the interior and cill trim, seat belt rails and consoles
To avoid ripping it, don't yank at it by gripping it round one of the cut out holes as it WILL rip
The accelerator pedal will be a pain, unclip the circlip at the top and carefully slide it off. BMW designed this as "disposable" meaning they expect it to break! But you can avoid it.
Kink the carpet up in the middle and lots of careful wiggling and a huge bag of swear words and it will be out
Voila!
and then you will probably see this :(
Hope that helps and good luck 8)
rich318i
Post Sun Jun 03, 2012 10:48 pm
use your feet to push the carpet back in to place or you never get it back right, top tip
Duke137
Post Sun Jun 03, 2012 10:54 pm
Forgot about that one! Too many cheat and cut it round the heater box :roll: Not been beaten yet myself and I have fitted 2 8)
Back on topic, you can actually buy the front inner wing and turret as a repair panel from BMW if your pockets are deep enough :)
craggsyE30
Post Sun Jun 03, 2012 10:56 pm
holy shit man thats crazy haha erm well since you can see the hole straight through could i first look underneith the car see if i can see an hole tlike that if not then rip carpet out and check it
Duke137
Post Sun Jun 03, 2012 11:00 pm
craggsyE30 wrote:holy shit man thats crazy haha erm well since you can see the hole straight through could i first look underneith the car see if i can see an hole tlike that if not then rip carpet out and check it
I stabbed it with a screwdriver and the small brown patch turned out to be a huge hole :(
What you see is 80% of the actual damage usually, that is why I say your arches and roof may be B.E.R (beyond economical repair)
Duke137
Post Sun Jun 03, 2012 11:05 pm
This is the only way to solve brown patches on an E30, as the wiki man said, you will buy yourslelf months only and the only people that bodge do it to sell on quickly after they have discovered the truth.
It is why there are so many teabags out there!
On the plus side an IS breaks well :) I hope it doesn't come to it for you mate, you seem keen and have a good attitude toward repair etc
craggsyE30
ah right well lets hope its just minor then haha if not well ill have to break it and sell bits get a bit of money outa it. but really if i can repair it ill be happy the roof is the sunroof so im not sure if theres any on the main part will have a good look tomoz. for the arches ill see if i can get the car jacked up and take the wheels off get a good look at then i was planning on replacing the wings anyway.
Duke137
Post Sun Jun 03, 2012 11:09 pm
Pop the rear door cards out dude... Good arches look like this :
Fooked ones look like this:
The fooked one is my red 318is (tech2 kitted) pictured in the avatar....
craggsyE30
Post Sun Jun 03, 2012 11:25 pm
right thanks alot duke mamte have you ran into alot of rust in your days with e30's and yh im keen i wont give up on the slightes bit of rust on how bit it was unless it was like at the point past repair. ill take the rear door card of first thing in the morning. may as well check everything else before repairing what i think to be the main problem when something could be werse
Duke137
Post Sun Jun 03, 2012 11:32 pm
craggsyE30 wrote:right thanks alot duke mamte have you ran into alot of rust in your days with e30's
You could say that, this is another fave rot place and in my opinion the worst, behind the glove box!
I attempted a repair but the rest of the car was much the same so I gave up and weighed it in!
Used an old Vauxhall Vivaro panel lol
Like I say, the rest of the car was fooked :( I moved on to better E30's you only need one rotten shitter to realise what to look for!
Kedge
Post Sun Jun 03, 2012 11:34 pm
Ferg, are you the new resident bodywork expert...........................Polsta will have something to say about this!!!! :rolling:
Oh and while you're bragging about your carpet fitting skillz you can come fit mine when it's ready to go back in winkeye
Instagram - Kedge85
Duke137
Post Sun Jun 03, 2012 11:38 pm
Kedge wrote:Ferg, are you the new resident bodywork expert...........................Polsta will have something to say about this!!!! :rolling:
I will help you out it is easier with 2 people!
I have sent enough over the scales now and have 2 half decent shells to save :D
craggsyE30
Post Sun Jun 03, 2012 11:42 pm
wow see iv never really had an older car to know what to look for i mean im good at repairing cars bodywise dents minor rust problems but when i saw the gaping hole i was like :| shite. but saying that iv seen people repair some right shit heeps to a good standard. one iv checked the car again tomorrow since i know what im looking for thanks to you guys ill see what state its in and hopefully its all good and only need that turret doing if so happy days if not well ill do my best. is there any other places i should be looking at bar the arches, turrets, sills etc ?
Kedge
Post Sun Jun 03, 2012 11:45 pm
This will make a good/scary read for you - http://www.e30zone.net/e30zonewiki/index.php/Rust
Good luck with it :cool:
Instagram - Kedge85
