shadow line trim keeps coming off
BATTS91
Post Mon May 28, 2012 9:38 pm
my shadowline trim on pasenger side keeps popping off at the wing mirror end , my pal had the same problem with his previous e30 , anything i can do other than glue it down as i really dont want to bodge it like that ????
BATTS91
Post Tue May 29, 2012 7:33 pm
seriously nobody has any advice , i was under the assumption this was common ?
Sanchez
Post Tue May 29, 2012 7:37 pm
put a cloth over the trim an gently squeeze the part that grabs the clip that grabs the flange with some pliers.
thats if the clips not missing that could be the problem.
Post Tue May 29, 2012 7:42 pm
As above,.There should be several rusty female clips set into the A post section of the moulding, crimp them slightly and for added insurance put a blob of araldite in the clip.
BATTS91
Post Tue May 29, 2012 8:46 pm
ok thanks i shall check in a mo whether the clips are there and take plyers out , its abit annoying when your passanger has to hold it on untill a suitable place to stop lol
Sanchez
Post Tue May 29, 2012 9:14 pm
Other problem is at the bend at the front can have a weak point and crack so be careful not to snap it when you push n pull on it.
