Bilstein shocks/ lowering springs Vs JOM coilovers
kangman
Okay money aside,
i always thought if you want super low you go for coilovers. But ive been looking at build threads and seen people weld there setups in etc.
I DONT WISH TO WELD ANYTHING ONTO MY E30 incase i want to bring it back to how it was originally
its also a 93 318i cab so does it have a different strut size?
Im going to put 16" split rims on it and lower it to the ground
Front-80mm Rear-60mm
SOo.. Advice on getting that drop please...
The handling will be ruined and you'll rip the sump off the first time you drive it.
oldroydsr4
The handling will be compromised ( you will notice more bump steer), however as its a 318i cab I doubt you will be racing anywhere any how. Although JOM stuff is cheap and rubbish, if you do coilovers do it properly, I.e gaz, bc, kw etc.
For a proper coilover set up welding is the only way due to the strut design, the option you have is to buy a spare set if struts and convert them.
With regards to the sump, you need a robust guard of some sort. On my previous e30 I made one out of 3mm steel and although it would occasionally hit the odd catseye, the sump was 110% intact.
Go for it ! Coil overs all the way. Your car will drive like a shopping trolly with a hinge in it but it will look bitchin' , so who cares !
- Homo Hair
No comparison.. The JOM's are wank. They don't even go that low.
harry_p
I you want it stupid low you may aswell just cut the springs and wire them into the seats to they don't dislocate under droop.
It'll handle like crap, but it will save you however much a set of cheap crap coilovers would have cost and given similar handling.
As has been said, if you wanted proper coilovers you'd be best off buying a spare pair of struts to modify with proper threaded collars and keep your existing ones to put back on if you ever want go back to standard.
cheers,
harry
harry
Tom_Maverick
To be fair the JOM coilies aren't as bad as some but they're still a bit naff, and as has been said they really don't go very low! As for an 80mm front drop, well, it's your car but it'll look shit, unless you are out throwing £1500 at a set of gotti / image / hartge splits or something really fresh you'll just look like you've cut your springs, super dooper low on cack wheels is not a good look, you'll also need to do some arch work too and work out backspacing (ET) as you don't want the wheel lost in the arch, you ideally want the forward most part of the wheel at the face of the arch, tyres will be critical too or you'll tear the arch lip down on the first bump and the second will use the lip like a knife and slash your tyre... There's a lot involved when you're ruining a cars handling, it's not just a case of dropping it and hoping for the best..
oldroydsr4
^ This.
Also, IMO you don't need to go that low on the back to get a e30 sitting right. The off the shelf lowing kits often tuck the rear wheel and leave a arch gap at the front , this in turn creates the ultimate council speed boat look and is shocking.
Realistically, you need 80mm front 50mm rear to get an e30 sitting 'right'.
Below is my previous M50 touring. .
The sump sat 50mm off the road and engine was lifted to allow the sump to sit above the cross member and guard being fitted.
For a daily driven car this is as low as I think is feasible on 15's(no speed bumps around here). 16's are really required to get an e30 sitting right that is still usable, also there will be less compromise on the geometry (lol).
kangman
Im going for a wide stance look, maybe BBS RS. 9js all round run them on 195/45/16.Tom_Maverick wrote:To be fair the JOM coilies aren't as bad as some but they're still a bit naff, and as has been said they really don't go very low! As for an 80mm front drop, well, it's your car but it'll look shit, unless you are out throwing £1500 at a set of gotti / image / hartge splits or something really fresh you'll just look like you've cut your springs, super dooper low on cack wheels is not a good look, you'll also need to do some arch work too and work out backspacing (ET) as you don't want the wheel lost in the arch, you ideally want the forward most part of the wheel at the face of the arch, tyres will be critical too or you'll tear the arch lip down on the first bump and the second will use the lip like a knife and slash your tyre... There's a lot involved when you're ruining a cars handling, it's not just a case of dropping it and hoping for the best..
im doing this for looks not performance, dont give a rats ass if i can't go round bends fast plus its a 318 how fast can it possibly go...
So should i go for a set of billies then and put it on small springs?
and which billies to go for and what brand springs??
kangman
that stance is perfect!! we got speed humps round here but we take them on at a angleoldroydsr4 wrote:
oldroydsr4
Cheers,
Worth noting its up for sale again by the new owner, who has since installed a s50 , needs a bit to complete but is only £3.5k.
cro320
I use mine on JOM every day...and I don't hit anything on the road, car is pretty low but still decent plus front IS lip at the front.
Ride is fine, supple, and much more pleasant that on previous setups
I had Bilstein B6 plus H&R sports and my teeth were falling out over bumps, I needed to change that so JOM was obvious choice for decent money. I don't say it's better than Bilstein/H&R combo just much more pleased for everyday car like mine.
If these die ever i will replaced them with D2S street coilovers
kangman
do JOM coilovers need welding in?
PLEASE POST PICS OF LOWERED E30s AND WHAT YOU DID TO GET IT THAT LOW
Tom_Maverick
An apex 60/40 kit on gas dampers (apex ones are good or boge or bilsteins, b4's really b6's are a bit harsh) is the nicest low setup I've seen and no welding required! You'll get a drop like F755 in my sig except a little lower on the front, 9x16 wheels with an ET of 15 and 215/40 16 tyres or 205/45 and pro rolled rear arches (archenemy.com) gave me no hassles, a nice ride (even 4 up) and looked the mutts..
Tom_Maverick
195's on a 9j will look sh!t.. All that uber stretch and poke is old hat, even with the stance boys.. 205's will give you a nice stretch and not too much pokekangman wrote:Im going for a wide stance look, maybe BBS RS. 9js all round run them on 195/45/16.Tom_Maverick wrote:To be fair the JOM coilies aren't as bad as some but they're still a bit naff, and as has been said they really don't go very low! As for an 80mm front drop, well, it's your car but it'll look shit, unless you are out throwing £1500 at a set of gotti / image / hartge splits or something really fresh you'll just look like you've cut your springs, super dooper low on cack wheels is not a good look, you'll also need to do some arch work too and work out backspacing (ET) as you don't want the wheel lost in the arch, you ideally want the forward most part of the wheel at the face of the arch, tyres will be critical too or you'll tear the arch lip down on the first bump and the second will use the lip like a knife and slash your tyre... There's a lot involved when you're ruining a cars handling, it's not just a case of dropping it and hoping for the best..
Its all about the 'gape'
kitch
Joms drop by 80mm. I'd go Joms at the front and a 60mm drop at the back.
Kos
+1 on the 195 45 looking shit. Too much stretch
A 205/40 or 45 will be better or personally a 215/40 is the best on a 9j
Personally I'd have an 8j on the front and 9j on the back, with 205/45 and 225/40 respectively
Morat
ROFL you're a bad manpacerpete wrote:Its all about the 'gape'
Morat
Also,
where is the OP getting the idea that he needs to drop 80mm? On 16s you don't need to be that low to fill the arches. Also, have you measured the gap between an M40 sump and the tarmac when the car is that low?
kangman
can i ask what set up your runnings a wheel and tyre speckitch wrote:Joms drop by 80mm. I'd go Joms at the front and a 60mm drop at the back.
kangman
I just remember being on pistonheads years back and seeing a mtech 325 cab dropped on borbet Bs 9js all round. And in the add it said it was lowered 80f/60r. 2 me it looked the business..Morat wrote:Also,
well before i start 2 lower it i will defo be fitting a sump gaurd first.
Im going to purchase the wheels before the springs, then get the measuring tape out and see what is actually do'able.
This wont be my DD but it will get used alot cus it puts a smile on my face when im in it.
Morat
Yeah, I'd definitely start with some measurements rather than take that advert as Gospel. An E30 dropped that far on 9j wheels would surely have had some arch work done as well.
Tom_Maverick
Mine was 60/60 on 9j's running a 215 and I had to have the arches rolled and more room made.. you'll never get it 80 without also rolling a bit of the shape out of the upper arch section underneath.. not just the outer lip.. depends whether you're going to put people in it or not..
that's 60 all round on 9j borbet A's with 215/40's
kangman
so if i was to go for bilstein B4 shocks and 60/60 or 60/40 would that work or should i go for b6 or b8?
what about h&r cups would they work?
i dont mind rollng/pulling my arches but thats all really no flaring.
Morat
If you're going that low you're better off with B6. They're stiffer than B4, but that's a good thing with the lack of suspension travel - and more importantly they're the right length for 60mm drops. B4 are for stock/slight drop and a more standard feel. B8 are for the same ride height as B4 (down to -30mm ish) but are stiffer, like a B6.
oldroydsr4
When quoting drops, it is more help if the brand is stated to, as -60mm spax will differ from -60 apex .etc.
kangman
really? i honestly thought they were all the same maybe a few mm out from eachother.oldroydsr4 wrote:When quoting drops, it is more help if the brand is stated to, as -60mm spax will differ from -60 apex .etc.
whats the best brand to go for? i want it to be firm not bouncy but not rock solid
oldroydsr4
I had a -60mm spax kit on a 325 a few years back and the back sat too low and front too high.
trevski
I fitted b4s with einbach pro kit today on my 325 vert and looks perfect along with the handling, witch is not surprising considering when I unscrewed and removed the old shocks I had to pour the oil out of the tubes as they both were shot! Perfect combo for me though subtle but handles and looks the nuts with my 15" ronal ls,s
kangman
http://www.ebay.co.uk/itm/BMW-E30-318i- ... 825wt_1105
these are the only springs i can find that lower 60f/40r...
i dont know what make they are HELP!!
Tom_Maverick
Apex do a 60/40 kit that is really, really nice.. check ebay!
kangman
cant find any for a 318i cab 1993
