Is this normal?
Mo13
Post Sat May 05, 2012 11:58 pm
small gaps on either side in the rear between the body and the hood when the hood is closed and locked in....think thats y there a lot of noise inside when driving.
rear left:
rear right:
Post Sun May 06, 2012 12:05 am
You can adjust the rear of the hood to sit down.
If you look to the the right hand frame, you will see an allen key bolt head, turn that and the rear will either sit or raise itself.
Mo13
Post Sun May 06, 2012 12:11 am
Rav335uk wrote:You can adjust the rear of the hood to sit down.
If you lookto the the right hand fram, you will see an allen key botl head, turn that and the rear will either sit or raise itself.
Brilliant! Thanks Rav
macas
Post Sun May 06, 2012 12:24 am
Yeah thanks rav!
Im been messing around with mine for ages tryin to get the fooker a little more down at the back!!
