Few small issues
phi1
Sun Apr 22, 2012 6:32 pm
Hi there
After a bit of help, I have a few issues with my e30 the windows are intermitant working sometimes work and sometimes don't any ideas?
Also the fan for the heater has stopped working, where should I check what could be wrong?
Grrrmachine
E30 Zone Wiki / Team Member
Sun Apr 22, 2012 6:34 pm
With the windows, is it all of them or just one of them? And do they work with the drivers or passengers door open?
As for the Heating, there's comprehensive info in the Wiki on that issue :D
http://www.e30zone.net/e30zonewiki/inde ... n_Problems
phi1
Sun Apr 22, 2012 6:49 pm
with the windows, both the windows stop working from both switches, and regards to the heater it's just the blower we are not getting volts to fuse 20 in the engine bay.
Gavla
Sun Apr 22, 2012 6:59 pm
Grrrmachine wrote:With the windows, is it all of them or just one of them? And do they work with the drivers or passengers door open?
What does it mean if they work with the drivers door open even when the ignition is off? Thanks
phi1
Sun Apr 22, 2012 7:09 pm
no when the ignition is on the windows sometimes work and sometimes don't.
Grrrmachine
Sun Apr 22, 2012 7:14 pm
Gayla, it means everything's working as it should. There's a relay that switches power directly from the battery to the window switches when the door opens, driven by the door trigger pin switches in the A-pillar.
phi1, if your system is tempremental it suggests a loose connection somewhere. I can't be more specific than that, but you ought to have this question moved to the Technical section.
