What are E30s like Rot wise these days?
Joshy
Post Sun Apr 22, 2012 11:49 am
Hi guys
Its been a while but I'm thinking about rejoining the E30 club and getting one with a M30 or M50/2 conversion.
Now, my main concern right about now is Rot. I'm not very lucky when it comes to buying, the Toyota Supra I bought a few months ago turned out to be rotten as a pear :x.
This could arguably be avoided by looking carefully, but I'm a man who buys with his heart not his head, so I find it a little difficult to remember to check if there is actually any metal in the arches :roll:
So, I was wondering, what's the state of play of E30s and rust? Are there many out there left that aren't going to need welding for a while yet? What are the odds of finding a genuinely rust free car at the lower end of the market for a converted car (Circa £1500-£2000)?
I've noticed looking at a few ads that people mentioning holes in scuttles and battery trays like they aren't big deals. I thought they were supposed to be major weaknesses for E30s, along with jacking points and sills obviously.
Long story short, I really like E30s (So much so that I can't consider a E36 because I find them so dull in comparison!), one with a M30 or M50 will give me the power I'd like along with reasonable parts costs, they seem perfect as to what I need right now in a car right now, I'm just worried about rust!
Any thoughts
blackE30indy
Post Sun Apr 22, 2012 12:23 pm
When looking at one,you wana be looking at the skuttle,bulkhead,battery tray,rear inner and outer
arches,boot pockets,back panel,and sunroof panel and tray,jacking points,sills
So overall not alot :eek:
these are the places you wana look
Cloggy Saint
Post Sun Apr 22, 2012 12:31 pm
Joshy wrote:What are the odds of finding a genuinely rust free car at the lower end of the market for a converted car (Circa £1500-£2000)?
Somewhere between zero and extremely unlikely.
pnd
Post Sun Apr 22, 2012 12:38 pm
you need to budget more either to buy a good one or pay to havee the rust sorted easy enough done but expensive.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Apr 22, 2012 1:41 pm
Get acquainted with the Wiki; it highlights all of the usual rust spots as well as a few fixes:
http://www.e30zone.net/e30zonewiki/index.php/Rust
There's also some restorations out there highlighting what's involved in putting rot right, linked on that page.
I'd say you're better off buying a shitter for 3-500 quid, stripping it yourself and paying someone else to fix the rust.
goosiegander
Zonegoose
Post Sun Apr 22, 2012 2:36 pm
Indeed, and without proper cathodic protection in the UK climate even the currently good cars are going to start going down the toilet rapidly in the next 10 or so years,
Assuming of course these are cars that will be used in all weathers...
Post Sun Apr 22, 2012 2:39 pm
They all rot. Some of the earlier Tourings seem a little more resistant to the tin worm but they are by no means immune to it - although I would hope that a £2k car wouldnt have that many issues.
Jozi
Post Sun Apr 22, 2012 2:48 pm
I think you'll struggle to find a good one with a engine conversion already done for 2k, it can cost that much to drop an m52 in. By on body condition, everything else can be replaced or added over time.
Joshy
Post Sun Apr 22, 2012 4:21 pm
This is not sounding too good. I don't want to deal with terminal rot, but I equally want a converted car but then don't have the space to do the work myself, neither do I want to spend more than £2000 (in fact £1500 is pushing it). It seems like the chances of me settling all of that sound unlikely? :cry:.
This is a car in the classifies that caught my eye, which the only thing putting me off is the mention of the rust:
http://www.ebay.co.uk/itm/140732352354? ... 586wt_1396
Cost wise how much would I be looking at getting all of that sorted out? (Scuttle, replacement inner and outer arches, etc?). Is this the sort of work I should expect to do to for this sort of money?
Grrrmachine
Post Sun Apr 22, 2012 4:47 pm
Welding isn't necessarily that expensive; it's the paint that adds to the cost. If the rust is limited to invisible areas (boot pockets, floor, inner wings) then you can repair it on a budget, but if a car has rusty arches then the whole rear quarter needs to be sprayed, and properly blended into the other areas. And that costs pounds.
I think you need to up your budget; anyone who's taken the time to put a decent engine into a solid shell won't let it go for less than two grand, I'd have thought.
suchy
True Zone Relic
Post Sun Apr 22, 2012 4:48 pm
Joshy wrote:This is not sounding too good. I don't want to deal with terminal rot, but I equally want a converted car but then don't have the space to do the work myself, neither do I want to spend more than £2000 (in fact £1500 is pushing it). It seems like the chances of me settling all of that sound unlikely? :cry:.
Sounds unlikely to me also! £1500 for a converted car (done properly) without any serious rust issues is indeed pushing it. You may find a hound with an M50 thrown in though but that's not an ideal car to own as it'll cost you waaaay more eventually and cause all kinds of inconvenience and grief.
Personally in your situation I'd buy the cleanest pov-spec and save for someone to do the conversion for me and add the tarty bits as I went along...
Post Sun Apr 22, 2012 4:52 pm
Inner/outer arch surgery will be at least £500 a side for a proper job.
Used wings in the right colour can be found with patience
The rot under the towing eye probably won't be "just" a patch job
If the scuttle is rotten the screen will need to come out to check it properly and you can almost guarantee there will be bulkhead issues lower down :cry:
For the price the one in the Ebay as wasnt a bad buy. If £1500 is your ideal budget I'd be looking for one which as a minimum has rear arches which don't need doing.
No mention of the front corners of the floorpan being good or bad either - if there are issues elsewhere on the car and no mention of this being attended to already you can safely assume they will need looking at.
Post Sun Apr 22, 2012 8:04 pm
Dezzy
CR24v it's a lifestyle
Post Sun Apr 22, 2012 8:18 pm
That is a nice base chariot there.
Loving the colour as well! :cool:
Joshy
Post Sun Apr 22, 2012 10:36 pm
I'll be watching that closely (Although I'm not really in the position to buy right now unless it goes for pennies).
Looks absolutely beautiful. Precisely what I'm looking for and what makes justifying looking for anything other than a E30 very difficult for me :cool:.
Dezzy
Post Sun Apr 22, 2012 11:03 pm
You'll not find anything better. The guy's who has it for sale did the conversion. They know these turds inside out.
This is a one time only chance to buy a correctly converted 24v chromie :cool:
Post Mon Apr 23, 2012 9:47 am
This.
Post Mon Apr 23, 2012 9:49 am
I don't think it'll be going for less than 2k though.. :wink:
mcbonio
Post Mon Apr 23, 2012 3:48 pm
As a few folk have stated, you'd be best buying an e30 based on the shells condition, then adding the engine you want and other bits as you go.
BATTS91
Post Tue Apr 24, 2012 1:47 pm
mcbonio wrote:As a few folk have stated, you'd be best buying an e30 based on the shells condition, then adding the engine you want and other bits as you go.
this ^^^ Buy with your brain not your heart
