1.8 m40 camshaft/valves/shims inspection-what to look for?
matt86
Post Thu Apr 19, 2012 4:45 pm
Hi thought rather than being lazy I'd finally get stuck in and get the socket set out to remove the rocker cover and inspect camshaft and cambelt, I know not exactly difficult, but everyone has to start somewhere :)
My question is what to look for, I will attach photos, but don't think you will see much from the photos, it all looks clean and cant see and chips or scoring on the camshaft lobes and valves look happy.
My problem is the car won't rev over 5000rpm and is sluggish.
let me know your opinions/thoughts.
Cheers.
Post Thu Apr 19, 2012 4:54 pm
its still the camshaft :)
matt86
Post Thu Apr 19, 2012 5:44 pm
Alex wrote:its still the camshaft :)
thanks alex, have done quite a bit on cars, but anything in the engine gets me worried, don't have a massive amount of confidence with things like this, just need to take my time I think, keep everything organised and just do it one step at a time.
redcar
My M40 did exactly as you describe. When the cam was inspected, it appeared as you describe yours to be in (clean and in good condition)
Don't really know what else could cause the problem unfortunately as the cam did look all good and ok :(
matt86
Post Thu Apr 19, 2012 5:48 pm
yes, its a weird one, I thought generally worn cams rattle like fuck too. Don't know whether to take valves and camshaft out and inspect more thoroughly.
Can;t understand it, the engine feels tired and has no go and stops at 5000 rpm, like its hit a rev limiter, none were restricted by ecu to 5000 rpm were they?
The thing is I plan to do a full service, but don't want to shed out money and find out something is screwed internally, although the car has only done 63000 miles, so even if neglected I doubt it would be knackered at this mileage.
cheers :)
JJ26
Post Thu Apr 19, 2012 5:55 pm
It wont necessarily rattle as these these engines use hydraulic tappets, any wear would be compensated to a point.
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
matt86
Post Thu Apr 19, 2012 5:58 pm
JJ26 wrote:It wont necessarily rattle as these these engines use hydraulic tappets, any wear would be compensated to a point.
oh ok so they have the self adjusting hydraulic tappets in the e30's, thats handy to know. cheers mate :)
redcar
Post Thu Apr 19, 2012 6:22 pm
Mine had the exact same problem Matt. It refused to go past 5000RPM, although mine was on 90k miles so a fair bit more than how many yours has on it.
It may be worth looking for a second hand known working engine because it would probably cost similar amounts by the time you've finished rebuilding the head on your one. winkeye
matt86
Post Thu Apr 19, 2012 6:26 pm
redcar wrote:Mine had the exact same problem Matt. It refused to go past 5000RPM, although mine was on 90k miles so a fair bit more than how many yours has on it.
Well mate, the plan was to put a m20 2.5 e30 engine and running gear in, but won't have the dollars for a bit as low on cash, so was just going to try and get this running better for the next few months, but might just drive it till I have the money for the conversion and put up with the fact that it is a slow piece of fucking crap and a fuel guzzler.
Only will be driving to e30 meets in it and a few bits of local driving anyway.
Think its probably worth me checking the cambelt, so I don't get stranded although I'm with footman james and they throw in free breakdown cover anyway. :)
redcar
Post Thu Apr 19, 2012 6:29 pm
Well mate, the plan was to put a m20 2.5 e30 engine and running gear in, but won't have the dollars for a bit as low on cash, so was just going to try and get this running better for the next few months, but might just drive it till I have the money for the conversion and put up with the fact that it is a slow piece of ******* crap and a fuel guzzler.
Yeh may be best to just leave it as it is, it's not like the m40 is any more powerful when it's revved past 5000rpm winkeye Still get beaten by everything :(
The m40 only did 25mpg on motorway runs, couldn't ever get it better than that.
matt86
Post Thu Apr 19, 2012 6:34 pm
Yeh think mine is doing between 15-25 mpg, you just have to drive it like a granny, maybe they are all just shit in general then, mine has no go in it at all unless you redline
it which is obviosuly no good for the engine on a regular basis and rinses fuel.
I have a 2 litre engine, gearbox and ecu, so could put that in and would just need to buy wiring loom and diff I believe?
But then it seem pointless to put all that effort in and only put a 2 litre in makes more sense to put the is engine in or m20 2.5 engine.
Think I will just have to put up with it and wait for the money to come in from my whoring. winkeye lol
matt86
Post Thu Apr 19, 2012 6:39 pm
I get small engined micras and stuff doing me and you really have to rev it up and drop the clutch to get the back swinging, the 2 litre in my 1st one would piss all over this, but yet according to the stats 1.8 m40 is 113 bhp and 2.0 is 133, so not a massive differnce, although I suppose 20bhp is still a fair bit extra, plus the 2 litre was a very healthy engine and I get the impression this one isn't mate.
What you running in your's?
JJ26
Post Thu Apr 19, 2012 7:46 pm
Not all E30's, just the m40 engines. M10 and M20 are manual. :)
ST185 GT4
E46 330d Sport
matt86
Post Thu Apr 19, 2012 7:48 pm
cheers mate handy to know, think I'm just going to check cambelt and run this enngine until I have money for the conversion or it blows up winkeye pretty shat engine in my opinion though compared to the straigh six ones, saying that mine may have had a abused life. :)
redcar
Post Thu Apr 19, 2012 7:55 pm
M42 is good engine
Billwill
Post Sat Apr 21, 2012 2:22 pm
I am happy with my M40...revs just fine!
If you remove the cam to inspect the rockers etc. for wear...first block off the small holes on the downhill side of the cam area where the oil drains back into the sump. Once the cam comes off the rockers go flying and the small metal disks on top of the valves go scurrying down those hole and into the sump. :eek:
Maybe the cam timing is a bit out.
As stated by redcar...the M42 is a nice improvement. If my M40 motor gets too tired I will look for a good M42/43 preferably from a late model E36 318is. :D
cypriot_boy_2k7
Post Sat Apr 21, 2012 3:30 pm
My mofos, I have same probs, but the rattle isn't loud, and I have roughly the same mpg as you guys, I'm taking my head off next week to inspect, has the car sat for a while and not been driven?
Martinaston
Post Sat Apr 21, 2012 4:26 pm
The cam gets worn because the oil doesn't flow through the tappets, they are a dead end so the oil is pushed in to pressurise them but then doesn't go anywhere.
It eventualy goes crusty and stiffens the internal spring so the tappet no longer compresses to the full depth.
That then causes the wear on the rockers and cam lobes.(and the low rev limit)
The best temporary fix is the remove the tappets and gently sqeeze them in a vice while trying not to damage the top or blow out the seal.
You can then re-use them as long as the cam is not fubar'd, otherwise you may as well just renew all the timing gear and be done with it, there's normaly a whole kit on E-bay for £260 thats about the cheapest you can get the whole lot for.
If you release the exhaust manifold and possibly the prop you should be able to tilt the engine up a bit and replace the cam without removing the head.
There is NO nucleus.
Andyboy
Alpina Colada
Post Sat Apr 21, 2012 4:44 pm
Eh? What are you on about? Taking the cam out of an M40 doesn't require the engine to be moved, or the prop/manifolds touched. It's 3 hours work start to finish.
The cam gets worn only because the spray bar blocks up. A ticking noise is a worn tappet, a 'clack clack clack' is a shagged cam. Turn the engine over and inspect the tip of each cam lobe. It should be smooth all across the width - if there are two wear ridges, the cam is U/S. It's more the worn rocker arms that cause the noise than the cam lobe.
As a temporary thing, you can buy a set of cheap new rockers and fit those, clean out the spray bar and see how you go. At the very least do the spray bar - it's worth opening up the oil holes with a very small drill just to make sure the lobes are well and truly oiled.
Martinaston
Post Sat Apr 21, 2012 5:05 pm
Pretty sure its due to stiff tappets, opening up the holes in the spray bar will just reduce the back pressure in the oil system and cause bigger problems over time.
Anyway the whole threads about more power from an M40 so its all a waste of time :roll:
Billwill
Post Sun Apr 22, 2012 8:57 am
No need to tilt up the engine to remove the cam...just block off the small oil-return holes with some old rags to stop bits falling into the sump. :)
While you have the tappet cover off..rotate the engine to TDC...there is a 8mm hole in the bell-housing just below the starter motor. Insert a 8mm bolt (or the bar for the spark plug spanner) into it while rotating the crack shaft with a 22mm socket and feel for the corresponding hole in the flywheel to lock the 8mm bar into. There are two positions that the bar will go in..one is TDC and the other is 360 degrees out on the crankshaft. At true TDC the camshaft has two little dimple on the flat surface facing upwards.
Now check that the camshaft is exactly level with the edges of the head...use a small straight-edge and a vernier to measure. if it is not pretty much level then that is your problem and you need to loosen the Torx bolt on the camshaft...rotate slightly till level and re-torque the bolt to 65 Nm. Turn the motor a few times by hand and re-check. You can rather use the special BMW cam locking tool if you can get one. :)
Andyboy
Alpina Colada
Post Sun Apr 22, 2012 9:39 am
Martinaston wrote:Pretty sure its due to stiff tappets, opening up the holes in the spray bar will just reduce the back pressure in the oil system and cause bigger problems over time.
. A bit like the 'advice' you give. It's got nothing to do with 'stiff tappets' FFS.
Andyboy
Alpina Colada
Post Sun Apr 22, 2012 9:44 am
Billwill wrote:No need to tilt up the engine to remove the cam...just block off the small oil-return holes with some old rags to stop bits falling into the sump. :)
It could be retarded cam timing. When setting TDC on autos though the flywheel locking hole is a lot bigger with more leeway. At TDC the lobes on no.1 cylinder are pointing upwards in a v formation (10 to 2) and the two machined flats on where the cam locking tool fits must be at 90 degrees to the machined top edge of the head - you can use a set square. My money's still on worn lobes and followers however.
