matt86
Post
Wed Apr 18, 2012 10:23 pm
Hi I have a 1.8 facelift convertible and the engine seems not very responsive, I think its long overdue a service and I'm hoping after doing this it will run much better.
My plan was to do plugs, oil, oil filter, fuel filter, air filter, coolant.
Is there anything else that I should do or anything will make it run better.
I.e does it have a idle control valve I can clean or is it worth taking anything off to inspect/clean things?
chh137
matt86
Post
Wed Apr 18, 2012 10:29 pm
chh137 wrote:Timing belt?
good point, will take the cambelt cover off and inspect it.cheers mate
Post
Wed Apr 18, 2012 10:39 pm
Check distributor cap, rotor arm and spark plugs. Replace as necessary.
Test AFM with battery and meter.
Check operation and adjustment of the TPS.
Check the resistance of the 'blue' temperature sensor when cold and at full running temperature.
Remove the injectors and have them rebuilt.
Check the fuel pressure at closed and wide open throttle.
Check compression on all cylinders, or better, perform a leak down test.
Inspect all air hoses and their joints on the inlet side of things, looking for splits, cracks and poor fitting.
matt86
Post
Wed Apr 18, 2012 10:44 pm
Brianmoooore wrote:Check distributor cap, rotor arm and spark plugs. Replace as necessary. Test AFM with battery and meter. Check operation and adjustment of the TPS. Check the resistance of the 'blue' temperature sensor when cold and at full running temperature. Remove the injectors and have them rebuilt. Check the fuel pressure at closed and wide open throttle. Check compression on all cylinders, or better, perform a leak down test. Inspect all air hoses and their joints on the inlet side of things, looking for splits, cracks and poor fitting.
Thank-you very much Brian, seems quite a intensive list, but will crack on with it, starting with the normal serviceable parts, then onto the rest of the things you have advised.Sorry to seem stupid but what does afm and tps stand for?Also the car won't rev past5000 rpm, could this be down to the fact that it needs a service or would you think its more likely a uncared for engine with worn internals ie camshaft etc?
Post
Wed Apr 18, 2012 10:53 pm
If it hits the 5000 RPM limit like a rev limiter cutting in, then it may well be a worn camshaft, and there's little point servicing an engine in that condition, which such a major fault.
AFM = air flow meter (on top of the filter box).
TPS = throttle position switch (on the underside of the throttle body, attached to the end of the butterfly spindle.)
matt86
Post
Wed Apr 18, 2012 10:55 pm
Brianmoooore wrote:If it hits the 5000 RPM limit like a rev limiter cutting in, then it may well be a worn camshaft, and there's little point servicing an engine in that condition, which such a major fault. AFM = air flow meter (on top of the filter box). TPS = throttle position switch (on the underside of the throttle body, attached to the end of the butterfly spindle.)
Thanks Brian for the info, I was planning at some point soon to buy and fit the m20 2.5 running gear when funds allow, but I may do a little driving in the meantime, so what would you suggest, leave it for now and just hope it lasts till I getthe parts for the conversion?
BMWE30325
Post
Wed Apr 18, 2012 11:05 pm
matt86 wrote:Brianmoooore wrote:If it hits the 5000 RPM limit like a rev limiter cutting in, then it may well be a worn camshaft, and there's little point servicing an engine in that condition, which such a major fault. AFM = air flow meter (on top of the filter box). TPS = throttle position switch (on the underside of the throttle body, attached to the end of the butterfly spindle.)
you can allways sell the seats and buy an 2.5 engine
matt86
Post
Wed Apr 18, 2012 11:08 pm
BMWE30325 wrote:matt86 wrote:Brianmoooore wrote:If it hits the 5000 RPM limit like a rev limiter cutting in, then it may well be a worn camshaft, and there's little point servicing an engine in that condition, which such a major fault. AFM = air flow meter (on top of the filter box). TPS = throttle position switch (on the underside of the throttle body, attached to the end of the butterfly spindle.)
But then I wont have anywhere to sit
I;ll keep you posted on the seats if I decide to sell.
BMWE30325
Post
Wed Apr 18, 2012 11:18 pm
matt86 wrote:BMWE30325 wrote:matt86 wrote:Thanks Brian for the info, I was planning at some point soon to buy and fit the m20 2.5 running gear when funds allow, but I may do a little driving in the meantime, so what would you suggest, leave it for now and just hope it lasts till I getthe parts for the conversion?
no worrys
StefanAnghel
Post
Wed Apr 18, 2012 11:21 pm
If you decide to have your M40 serviced...I have lots of good service parts from my old M40 that i've took off...
Timing belt and tensioner used for only 8k, 4 months old spark plugs...need to check the service history to give you all the details but you van have them for postage money and some donation to the forum!
Let me know and i'll get them out for you
matt86
Post
Wed Apr 18, 2012 11:26 pm
StefanAnghel wrote:If you decide to have your M40 serviced...I have lots of good service parts from my old M40 that i've took off... Timing belt and tensioner used for only 8k, 4 months old spark plugs...need to check the service history to give you all the details but you van have them for postage money and some donation to the forum! Let me know and i'll get them out for you
that's very kind of you mate, although I don't know how bad the engine is internally and what it may need, it sounds as thought there's a chance the camshaft is knackered.I would probably need cambelt, camshaft plugs etc, but haven't decided where to go with this yet to be honest as may swap the engine in a couple of months, so may be a waste of money, I'll let you know, but thank you for your kind gesture
StefanAnghel
Post
Wed Apr 18, 2012 11:34 pm
My camshaft was good and you can have that also...easy thing to check...take the cam cover out and oil splash protector and check if the cam has a lip on it i should have a picture somewhere....
matt86
Post
Wed Apr 18, 2012 11:44 pm
ok how much do you want for the lot posted? Or I may be able to collect possibly.
If it only revs to 5000 rpm and the camshafts worn, will it only be the camshaft worn though or may other bits need doing, or should this resolve the problem?
thanks mate
matt86
Post
Thu Apr 19, 2012 11:26 am
my tappets aren't noisy, so can I get away with just changing the camshaft do you think, its more loss of power and won't rev over 5000 rpm.
What do you want for camshaft, cambelt, plugs?
cheers
polsta
Post
Thu Apr 19, 2012 11:52 am
youd need a gasket set aswell, and if its apart,its a chance to get the rocker and injectors refurbed aswell, would be daft not to do the injectors
StefanAnghel
Post
Thu Apr 19, 2012 3:47 pm
matt86 wrote:my tappets aren't noisy, so can I get away with just changing the camshaft do you think, its more loss of power and won't rev over 5000 rpm.
cheers
Come and pick them up if you can and few beers or a donation to the zone will do!
Post
Thu Apr 19, 2012 8:35 pm
What does need to be addressed is why the camshaft wore in the first place? A blocked spray bar, badly neglected oil changes, or a combination of both?
twoscoops
Post
Thu Apr 19, 2012 8:43 pm
Good interesting thead with some good advice
matt86
Post
Thu Apr 19, 2012 8:51 pm
Brianmoooore wrote:What does need to be addressed is why the camshaft wore in the first place? A blocked spray bar, badly neglected oil changes, or a combination of both?
Brian, it doesn't really look worn though, is there a way of measuring the lobes, or anything to look for or is it hard to diagnose a worn camshaft, I wouldnt say theres and engine noise and it doesnt realy look worn.
at a guess I'd say oil changes, may just service it and see what difference it makes and if no change, wmaybe try another camshaft and check all the clearances, valves, shims etc.
matt86
Post
Thu Apr 19, 2012 8:52 pm
twoscoops wrote:Good interesting thead with some good advice
Yes it has been a very helpful thread thanks to all, there is some very knowledgable people on here especially Brian, cheers mate.
Post
Thu Apr 19, 2012 10:50 pm
The full width of the cam lobes isn't used. Only the middle, shiny section will be worn, so check for a ridge when you run a finger nail across the tip of a lobe.
Only the outer surface of the metal a cam is made out of is hard, and once this layer is worn through, further wear will be extremely rapid.
Kos
Post
Thu Apr 19, 2012 10:59 pm
if ti helps i have perfect dizzy cap here and set of leads.all have done less than 10,000 miles
a sensible offer and they are yours
matt86
Post
Thu Apr 19, 2012 11:13 pm
Brianmoooore wrote:The full width of the cam lobes isn't used. Only the middle, shiny section will be worn, so check for a ridge when you run a finger nail across the tip of a lobe.
thanks brian I will check this tomorrow afternoon. is there anything else that may cause the symptoms I have or would you say it is something worn within this assembly?
thanks again
