mtechnics bagde on spoiler?
hi all, just wondering, when i brought my 320i it had which looks like a tech 2 spoiler, it doesnt have the mtechnics badge on it, is it a replica if it doesnt have the badge?, thanks
adit
badges can always fall/be taken off. you can tell if it's genuine by looking at the underside for the bmw logo and part number.
also, genuine ones are a lot heavier than the hollow fibreglass replicas
[quote="bss325i"]
rich318i
should have a bmw stamp at the underside of the top part of the wing one of the corners and the mtec sticker should be on the lower part of the wing on the right hand side. moody wings sound hallow when u tap them
Dezzy
- CR24v it's a lifestyle
Adit, do the reps get bolted through the bootlid in the same way as the original ones?
adit
no Dez, they do not have studs, so are usually bonded on or Tiger Sealed, etc
[quote="bss325i"]
Dezzy
That was my understanding.adit wrote:no Dez, they do not have studs, so are usually bonded on or Tiger Sealed, etc
Easy to spot a fake then!
320
mines bolted, but where the bage would normally be theres no sign there wsas 1 there, is there an indent where the badge sits?
adit
yes, (part no. 9) on the far right of the lower section iirc
[quote="bss325i"]
320
does the rep come in seperate parts, mine are seperate, but no indent for the badger, ill have a look tomorow to see if the stamp is underneath, tghe bolts seem to be the the same as on mine.
adit
no, one piece.
your spoiler may well have been repainted/"fillered" at some point, stickers don't prove anything, although the indentation should still be visible.
you will need to check for markings and post a photo up here
[quote="bss325i"]
320
http://www.r3vlimited.com/board/showthread.php?t=189849
heres a site that some1 sells rep seperate peice spoilers, thats prob where its from as they look similar, the 320is and the 1 underneath shows theres no badge.
adit
the red and silver ones shown in those pics DO show the indentation, far right
you can still buy the stickers from the dealers i believe
[quote="bss325i"]
suchy
- True Zone Relic
This is correctadit wrote:you can still buy the stickers from the dealers i believe
macas
So what are the two fixings holes for at each end of the spoiler for(where it hangs over onto the rear quarter),Actually they seem to be studs on the diagram above?
adit
they are for part 5 (plastic brackets that "tie" the spoiler to the bootlid, by means of two plastic nuts)
[quote="bss325i"]
macas
Actually tom it seems to be a replica then because that diagram shows studs on the overlap sections where yrs hasnt.320 wrote:hi all, just wondering, when i brought my 320i it had which looks like a tech 2 spoiler, it doesnt have the mtechnics badge on it, is it a replica if it doesnt have the badge?, thanks
320
Do the bolts on the ends come out, like the bolts on the rocker cover, if 1 snaps it can be replaced, do these bolts work the same way or are the studs welded in to the spoiler?
