Bit disapointed with my new E30 **SORTED**
jimf
Post Thu Apr 12, 2012 10:36 am
Hi folks,
I bought my 325i cabriolet last september and over the winter I've been tinkering and fixing what I can to bring it back from a slightly neglected state. I drove it home 500 miles with, a dodgy starter, unbalanced wheels, leaky roof, one speaker working and numerous other faults. Regardless of having just spent my hard earned money on this shed it didn't matter, the sun was out, the roof was down and I really enjoyed the drive. I saw the potential with it.
So the last six months I have had welding done, replaced the leaking roof, sorted the wobbles with new spiggots and tyres, reloomed the stereo, replaced the drab interior with a lovely cardinal red one and replaced anything broken, worn or non OEM with something more suitable.
The car now looks much more like it should now and it went through its MOT the other day. I was really looking forward to getting it on the road but when I did I was really dissapointed with the drive. I am used to driving E34's, I've had a number of them now and the E30 doesn't feel right in comparison. It feels loose, flimsy, the steering is vauge, the gears are sloppy and all in all it just doesn't feel like a BMW should.
Am i expecting too much by comparing it to the 5 series or is it worth starting to replace everything to make it feel like i want it too? The garage advised me to replace the steering UJ which would be my first port of call i think. Then the gear linkage requires attention which would be the short shift conversion I think. Any other suggestions?
tom325sport
Post Thu Apr 12, 2012 10:44 am
Cabs do have 'scuttle shake', but shouldn't feel flimsy in my opinion. Have you changed any of the bushes? Is the car on standard suspension? People change the whole steering rack to an e36 one i think. Any pictures of your car?
These cars are old remember but it should put a smile on your face - not the other way round.
bigwinn
Post Thu Apr 12, 2012 10:46 am
Change the rack as a starter for ten, an e36 is common choice to sharpen up feel?
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
bigwinn
Post Thu Apr 12, 2012 10:47 am
Stu
Rtaylor2208
Going on everything else you have mentioned that was wrong with the car I would suspect that its most likely running all original suspensionwhich after 20 years will have seen its best.
It starts getting quite expensive to replace everything but will make a huge difference to the overall handling.
PeteE30Touring (i think thats the zoner) did this recently and has a thread with pretty much all the details.
Replacing the gear linkage with a short shifter from a Z3 is a good upgrade as is a newer rack from a E36 \ E46 \ Z3 will also sharpen up the steering.
All of the above is also covered in detail in the wiki.
Topblag
Post Thu Apr 12, 2012 11:02 am
I'd suggest that you get a shot of another E30 cabby to clarify whether your car is very loose or you're just not used to old cabs handling characteristics.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
jimf
Post Thu Apr 12, 2012 11:21 am
Thanks for the replies guys,
I have felt the scuttle shake when on a particularly uneven surface, I can live with that.
The suspension seems in good order. I think vauge steering is the major issue here. I will look into changing the steering rack but I thought the E36 rack just changed the number of turns for lock to lock.
Post Thu Apr 12, 2012 11:23 am
People are to quick to say "put a z3 short shift" in when someone complains of a sloppy gear change.
Yes replacing the stick alone will shorten the throw and if using a new part along with the white plastic socket will take out some of the slop but there are other components that WILL be worn the will effect the gear change and these need to be replaced to tighten it up.
polsta
Post Thu Apr 12, 2012 11:36 am
^^^ what he said , ive drove e30s standard with sloppy gear change/worn, and quick shift, and my 325 has no quick shift, but has all new gear linkage replaced,and feels very nice and tight
steering should not feel vague, maybe as above a new rack and all bushes checked, youve done the rest, so now its time to move on to the drive, these are old cars, but you can get them feeling super
clipper
Post Thu Apr 12, 2012 11:46 am
Are you sure that it just doesn't feel "light" compared to the E34?
Never driven an E34 but I've had a couple of E39s and they "feel" far heavier to drive than the E30, it could just be that.
My E30 feels like a go-kart aftre driving the 39.
jimf
Post Thu Apr 12, 2012 11:51 am
Yes it does feel light compared to the E34 and E39. But if i point the car in a straight line i can move the steering wheel a few inches to the left and right with no output at the wheels and there is no resistance making the wheel feel loose.
it must be a worn UJ and possibly the rack.
Morat
Post Thu Apr 12, 2012 12:12 pm
Check the rubber guibo in the steering, you shouldn't have play around the straight ahead.
http://www.e30zone.net/e30zonewiki/index.php/Steering
Post Thu Apr 12, 2012 12:14 pm
Number 14 is the selector shaft knuckle and normal is worn.
Number 6 is the stick which moves in number 7 the socket ring and both parts wear at the ball joint and socket.
Also the bush at the bottom of 6 wears creating slop in the link between the selector uj and stick.
Number 2 and number 4 are bushes for the stabiliser and can get sloppy.
To refurb the complete shift mech you need,
2,4,6 (6 from a Z3 1.9 if you want a shorter shift),7, 14 (14 comes with 18,19,20), 2x12, 2x15, 16 and its worth getting a 13 and a 17 incase you break/lose the old ones.
jimf
Ok, thats the second time i have read that word 'guibo' today. I don't know what that is? :o:
Morat
Post Thu Apr 12, 2012 12:16 pm
It's a rubber coupling. Check the wiki link above and it's in the "common faults" section :thumb:
johnl320
Post Thu Apr 12, 2012 12:24 pm
Check the state of the rear subframe bushes as well, mine passed an MOT with them absolutely fooked
Post Thu Apr 12, 2012 12:27 pm
Gear linkage is a very worthwhile job to do even if you don't go down the short-shift route.
Personally I really like the standard setup and with all the worn components replaced it feels superb.
Unfortunately if you don't have access to a lift doing it on axle stands is a horrible job.
Post Thu Apr 12, 2012 12:29 pm
jimf wrote:Yes it does feel light compared to the E34 and E39. But if i point the car in a straight line i can move the steering wheel a few inches to the left and right with no output at the wheels and there is no resistance making the wheel feel loose.
If the guibo is that worn it probably shouldnt have passed the MOT 8O
I had an advisory on mine last year as there was a little too much movement in it but as there were no signs of cracking they passed it as an advisory.
jimf
Post Thu Apr 12, 2012 12:43 pm
Is this what we are talking about? No.3 in the diagram?
http://www.realoem.com/bmw/showparts.do ... g=32&fg=30
Jos
Post Thu Apr 12, 2012 12:45 pm
That's the one!
'94 e36 tree climber
jimf
Post Thu Apr 12, 2012 1:49 pm
Ok, well I best get to work then. Thanks for all help.
Post Thu Apr 12, 2012 2:00 pm
Sure it's not something as simple as the front tracking not correct, and it has toe out? E30 steering should be pin sharp when compared to an E34 and its old fashioned steering box.
polsta
Post Thu Apr 12, 2012 2:03 pm
capri_rob wrote:Gear linkage is a very worthwhile job to do even if you don't go down the short-shift route.
agreed, it also allows for faster pull away i think, with all new linkage it makes a big difference over worn/factory parts and feels much nicer, quick shift is great particularly the higher gear changes, but its not the best for a rapid pull away, although the feel of quick shift is great and makes the car feel more sporty/modern in that sense
BenHar
Post Thu Apr 12, 2012 2:20 pm
Brianmoooore wrote: E30 steering should be pin sharp when compared to an E34 and its old fashioned steering box.
Only the v8s have a box , I think? The sixes have a rack?
Ben
Gert_8
Post Thu Apr 12, 2012 2:28 pm
jimf wrote:Hi folks,
Not being funny Jim, but didn't you notice any of the problems when you drove it 500 miles, home?
Tom_Maverick
Post Thu Apr 12, 2012 2:33 pm
I can't stress enough the amazing difference changing the bushes, droplinks, topmounts and springs and shocks makes.. then get the tracking done and all of a sudden she's back to being an animal that you can flick round the bends and sticks like glue! I did all that to mine recently and in total it still probably cost less than a major service on a new BMW and what a difference it makes..
everything under your car is 20+ years old and worn... get changing! :D
jimf
Post Thu Apr 12, 2012 2:35 pm
Gert_8, That's a totaly fair question and I have to admit that i didn't notice the poor steering amongst all the other issues. I think now i have resolved most of them I'm starting to focus on individual things now.
jimf
Post Thu Apr 12, 2012 2:38 pm
I will Tom, one thing at a time, but I will. Need to get this steering thing sorted first.
Post Thu Apr 12, 2012 2:39 pm
Ben
Then you think wrong. I owned a 1988 E34 535iSE (converted from a 525iSE), and it had a steering box. The steering was less responsive than an E30s, and a bit vague feeling about the centre position - this is to be expected from a steering box, which always have some 'slop' in them.
Rich320I
Post Thu Apr 12, 2012 2:41 pm
+1 to what tom said im slowly doing the same (when cash flow allows) drop links top mounts etc after just changing the drop links and the wheel bearings all round its made a dramatic difference, like the other chaps have said after 20 years of use parts will need a refresh but you’ll notice the difference immediately. :D
jimf
Post Thu Apr 12, 2012 2:44 pm
Is there a logical order to replace things, for us guys that cant afford to do the whole lot in one go?
Gert_8
Post Thu Apr 12, 2012 2:54 pm
jimf wrote:Is there a logical order to replace things, for us guys that cant afford to do the whole lot in one go?
Is that the car in question? I saw this when it was being advertised for sale - looked promising. I can totally see your disappointment now, it should drive as well as it looks!
Post Thu Apr 12, 2012 3:12 pm
No point replacing bits and pieces a bit at a time - if the worst comes to the worse do the entire front end first ( easy-ish ) and then when you tackle the back end which involves dropping the rear beam off as the exhaust and prop have to be disconnected anyway that is the time to replace the prop guibo, centre bearing and refresh the gear linkage - as well as all the bits that wear out at the back end - so thats :
Beam bushes
Trailing arm bushes
Drop links
ARB Bushes
Top mounts
Spring pads
Diff bush
When the beam is off the car and out of the way that is then the time to examine the brake pipes which will then be accessible and if they havent been replaced before will almost certainly need it.
Also a good time to examine the fuel tank - if it leaks the time to change it is with the beam and associated bits off the car.
A rear end refurb can turn into a very big job depending what you find as you go along - I've been there and it can get expensive very quickly to do properly if a lot of stuff is worn out.
I ended up replacing all manner of other stuff - brake flexi hoses, handbrake cables, wheel bearings, brake backplates as well as various clips, bolts, nuts etc.
It can be difficult to assess what you need before you start - get it up in the air and make a list before you start undoing anything !
jimf
Post Thu Apr 12, 2012 3:19 pm
Sounds scary. Like I say I'll get this steering issue done first and them go from there. This all sounds like a good winter project. The car has been in the garage long enough now. It need run for a while while the to do list gets ever longer.
I really do enjoy working on it, just want to enjoy driving it too!!
BenHar
Post Thu Apr 12, 2012 3:20 pm
Ben
Yep, sorry. My memory playing tricks on me (again). I had a 530i V8 and it had a box but thought the small sixes had a rack. But it seems that only the M5 did.
Ben
