E30's chronic rear camber..
My e30 is slammed with borbet A's 16" 9j with coilovers sits perfectly but the camber it has now got is shredding the tyers in no time, might look the part but at a high cost!! Do not want to raise the car atall, have looked at camber adjusters on eBay but only find front ones anyone with any other suggestions or links? Cheers
ross_jsy
Suggestion is to raise it.
You can get camber correction tabs and bolts, believe Danthe does them. Also you can raise the subframe which effectively brings the trailing arms closer to their original position. This is done with subframe bushes
Kmac camber kits are also a very good alternative...
