any idea how much......
steve_k
Post Wed Apr 11, 2012 10:08 pm
.....to get a piece of alloy cut to the size of the cubby hole on front of the ashtray in the centre console with to 64mm holes in it?
I only ask as I've got a pair of 64-65mm mechanical gauges in the tool box I want to fit in the car.
one's a oil temp & pressure gauge (dual face) & the other is a voltage gauge.
also does anyboy know of anyone in the Mansfield area who could make this mounting plate for me??
help me out here please folks.
thanks in advance.
almost forgot to add that I'm after a mounting plate like this as I really don't fancy cutting two big holes in the centre console, but I don't mind cutting two little one's for the pipe work to pass through.
adit
Post Wed Apr 11, 2012 10:22 pm
[quote="bss325i"]
steve_k
Post Wed Apr 11, 2012 10:39 pm
Adit, I can't veiw your pic at the minute as I'm on my phone doing this & it's playing up.
the type of mounting plate I'm on about is the same kind that I'm sure hartge used & IIRC was for sale on r3vlimited a while back from euwerks.
I hope you understand what I mean?
adit
Post Wed Apr 11, 2012 11:03 pm
i think Kos may have some info about mounting plates Steve.
i don't know if these people make them suitable for E30s:
http://www.ebay.co.uk/itm/BMW-E36-VDO-G ... 27b8e22381
[quote="bss325i"]
steve_k
Post Thu Apr 12, 2012 9:17 am
Cheers adit, the only pic I can see at the moment is the bottom one (hartge) & yes thats the type I'm after but with two holes for a pair of 65mm gauges.
I might send a messeage to that seller on eBay & see if they know where I can lay my hands one one.
Post Thu Apr 12, 2012 9:53 am
Ask Kedge on here, he had some made a while a ago.
steve_k
Post Fri Apr 13, 2012 8:00 pm
@adit & rav, thanks for that I'll PM both kedge & kos & see what results I come up with.
Post Fri Apr 13, 2012 8:20 pm
Mine - bought from Kedge, leather trimmed by me :chuckle:
if you don't smoke you don't need an ashtray :D
steve_k
Post Mon May 07, 2012 1:48 pm
Right just found out I can get a flat black rectangular panel with 3 holes precut into it for 52mm gauges (so might go for those instead) but what I'd like to know is how hard would it be to cut it to shape without it breaking or shattering??
steve_k
Post Wed May 30, 2012 5:07 pm
Well I finally got my arse into gear & bought the mounting plate from revotec & three 52mm gauges (oil temp, oil pressure, & amps).
just got it cut down to size & now I just need to suss out how to fit it lol.
fingers crossed I should have it done in the next few days.
