325 sport ecu
wxwxwx
Post Sun Apr 08, 2012 7:26 pm
Evening all !
Ive just bought a 325 sport thats been parked up unused for 4 years. Its not in the best condition and also a non runner.
Ive narrowed it down to an ecu fault by following the guide on here about bridging wires ect. I removed the ecu and its full of water !
What im trying to find out is,will any 325 ecu fit or will it need to be a sport one ?
My car is an H reg,1990 i think
Thanks in advance
Post Sun Apr 08, 2012 7:28 pm
any age related 325i Ecu will fit, the sport ECU is no different
Grrrmachine
E30 Zone Wiki / Team Member
Enginewise, a sport is no different to any other 325, but you do need to find an ECU from a car of 1988 or later vintage, otherwise it'll have the wrong engine management system.
wxwxwx
Post Sun Apr 08, 2012 7:31 pm
Thanks.
Would my ecu be doomed or would it be ok drying it out for a few days ?
Grrrmachine
Post Sun Apr 08, 2012 7:38 pm
Electrics + Water = Fail. Even if the water wasn't in there for long, as soon as you cranked the car you put 12V through the system; with water in the mix, the ECU will definitely have suffered from it.
Was it the Engine Troubleshoot part of the Wiki that you used?
wxwxwx
Post Sun Apr 08, 2012 7:42 pm
I searched it on this forum last night,very helpful indeed
Andyboy
Alpina Colada
Post Sun Apr 08, 2012 8:03 pm
wxwxwx wrote:Thanks.
It needs what is known in the trade as a distance test.
That's a test of how far you can throw it. :D
wxwxwx
Post Sun Apr 08, 2012 8:06 pm
I guess i better chuck it in the bin then.
Anybody got one for sale ?
Dezzy
CR24v it's a lifestyle
Post Sun Apr 08, 2012 8:36 pm
You should have no problem finding a replacement ECU.
It will not be alot of coin either.
The car has not move for years and its ECU is full of watter :eek:
You'll need to find out how the ECU got wet in the first place!
I fear for you :(
Post Sun Apr 08, 2012 8:37 pm
wxwxwx wrote:I guess i better chuck it in the bin then.
sure... how many do you want ? :D
rich318i
Post Sun Apr 08, 2012 8:39 pm
wxwxwx wrote:Evening all !
Thanks in advance
is it a auto?
wxwxwx
Post Sun Apr 08, 2012 8:42 pm
Dezzy wrote:You should have no problem finding a replacement ECU.
I fear for you :(
There is a hole in the scuttle the size of a £2 coin so im guessing its coming in there !
All the water is still inside the car so i guess the floor pans are good !
wxwxwx
Thanks in advance
is it a auto?
Manual
Dezzy
Post Sun Apr 08, 2012 9:30 pm
I fear for you :(
You need to get the.....
Kit off
carpet out
check the sunroof
remove the boot carpet
If the scuttle is rotten, there will be more :(
BATTS91
Post Sun Apr 08, 2012 9:38 pm
Dezzy wrote:If the scuttle is rotten, there will be more :(
this is a definate if your rust hunting whip the dash out aswell or atleast the glovebox
wxwxwx
Post Mon Apr 09, 2012 9:50 am
How much do you want for one ?
