Post
Mon Apr 09, 2012 10:38 pm
The ideal mixture for an engine to run on is a mix of an inflammable gas and air mixed in the appropriate ratio. The enlightened amongst us do just that, using propane as the inflammable gas.
If you use petrol as the inflammable part, you come up against the problem that this is a liquid at normal temperatures. To overcome this disadvantage, the petrol is sprayed into the engine under pressure through fine nozzles which produces a fine mist of very small droplets.
These droplets are introduced into the inlet manifold, and immediately start to join together to form larger droplets, and to wet the manifold walls. Ideally, the injection is done when the inlet valve is open, so that the mixture is drawn into the cylinder as quickly as possible (full sequential injection), but the E30s ECU isn't this advanced. What it can do, though, if it knows which cylinder is finishing its exhaust stroke, is, under certain operating conditions, to fire three injectors at a time, which minimises the time the mixture waits in the manifold.
If the signal from the sensor in question is missing, the ECU has no option but to always fire all the injectors together, effectively doubling the average time the mixture has to settle out in the manifold, and thus wasting fuel.
