Anyone else's cab aerial whistle annoyingly!
jimf
Hi folks, just wondering if anyone else ever had this issue. I have fitted an aftermarket manual telescopic aerial to my cab project and on it's way to the mot I had the chance to get the roof down. The initial experience was ruined by the noise of the aerial whistling like a knackered kazoo in the airflow. Had to stop and retract the stupid thing. Obviously it has to go unless anyone else has any ideas how to stop it?
A perfect illustration of the difference between OE and aftermarket parts.
miniblob
Never noticed any noise from mine - probably because i haven't fixed it and it still doesn't go up
Radio still works ok most of the time though - depending on how built up the area is!!!
Also, perhaps with an auto one you wouldn't notice as much, as it would only be up if you are actually listening to the radio!!!
327 Touring with bass!!!
lamby
got a bmw one in mine and with roof down no whistle or noise from it,mine connected through ignition so i dont have to keep turning radio off to retract it.point is stereo not on but ariel up no whistle
kman82
why would you want the stero off and the aerial up? they look crap with the roof down
mrLEE30
mine was OEM and it did not whislte, but it did make a wishing noise that i found annoying, more so when i was using stereo to listen to my ipod FM transmitter, and thus didnt need the ariel.
i added a second rear demister switch and routed the ariel control lead through that, so if it was a particularily annoying night i could simply retract it.
jimf
mwggriffiths
I'm about to do the same thing with the electric window cut off switch. Wire it in next to the demist inline with the aerial trigger from the stereo for manual overridejimf wrote:Thats a great idea about the demister switch, would like some more details on that.
1990 318iS, 1998 E36 328i Touring, 2001 740i Sport, 1971 Range Rover
jimf
mwggriffiths
I need to work out how to do it neatly myself firstjimf wrote:I'm not great with electrics and wiring, How about a guide, i'm sure many others will benifit.
If this is the rectangular 'switch' with a lightning symbol on it, and a red band around it when the button is out, it is NOT a switch, and won't survive long if used as one.mwggriffiths wrote: I'm about to do the same thing with the electric window cut off switch. Wire it in next to the demist inline with the aerial trigger from the stereo for manual override
mwggriffiths
I had read that, but I didn't want to use the demist switch as mentioned above and I had this lying around.Brianmoooore wrote:If this is the rectangular 'switch' with a lightning symbol on it, and a red band around it when the button is out, it is NOT a switch, and won't survive long if used as one.
We'll see how long it lasts and go from there. If it breaks I have something new to tinker with
But it's not a switch - it doesn't have the mechanical toggle latch that an on/off push button switch needs. It only 'switches' off when you push it if you push off centre, because this distorts the hair trigger of the catch that holds the button in.
The demister switch (logo easily polished off) is a 'proper' switch, and can be modified to light up with the rest of the switches and gauges when the lights are on.
polsta
i invented that mod i think
i posted it up on here back at the time , hadnt seen or heard of anyone else doing it
what i did...
i used a fog light switch (you can use any you wish) with the 2 plain black buttons
the electric ariel BLUE remote wire that goes to stereo , goes through one of the switches
and i put the sub blue remote wire to stereo, through the other
put the switch in the spare blanking bit
then i had push button switch for the ariel, to keep it down most of the time , and pretty cool having it up/down at touch of a button on the odd time i wanted radio, also keeps the ariel nice and out of the weather
and the sub on/off at push of a button for times you didnt want all the bass, like when having passengers and talking etc
very easy to do and takes 10 mins and is a cool little mod
what i did...
Plain white wire with OE wiring. Plain blue wire is road speed controlled volume.polsta wrote:
mwggriffiths
Blue is the colour as it comes from an ISO loom found on most after market stereos so the input to the switch maybe blue (from the stereo) with the output white (to the antenna). That's probably where the confusion has come fromBrianmoooore wrote:Plain white wire with OE wiring. Plain blue wire is road speed controlled volume.polsta wrote:
jimf
mwggriffiths
On the antenna there is a ground, 12v and a trigger wire, the wire from the back of the stereo acts as the trigger. When this trigger is zero (stereo off) the antenna retracts, it extends when it receives 12v. The antenna moves when the voltage changes - so yes it does need a constant 12v at the trigger to remain up. Unless you raised it then unplugged all the wiring!jimf wrote:If you used a foglight switch or a demist switch, does that mean power will be constantly on while the aerial is up? Is that how the aerial works, and when power is taken away it goes down?
The switch is placed inline on the trigger. When the switch is closed the voltage at the antenna is that "sent" by the stereo ie the antenna will go up and down as you turn the stereo on and off. Opening the switch will break that circuit which means the antenna "recieves" 0v and retracts. This is essentially overriding the stereos 12v.
The other way it could be wired is to switch between 0v and a constant 12v - this gives direct control so you could have the antenna up when the stereo was off (if you were a bit weird and wanted that sort of thing....)
polsta
^^ as above, im no wiring expert and used the blue remote wires for mine, wasnt an oem stereo and the ariel it has was a fairly new one previous owner had got from munich legends
but its a good mod to do, just easy to do and nice to have the ariel on the button, and if you ever wanted to take it out its just a case of remove the switch and connect the wires back together, escpecialy handy if like me you rarely listened to the radio, and also saves wear/tear on the actual ariel keep going up/down every time you turned the ignition on, which got annoying
