Me and my dad had some classic time working on the e30 today. doing a sump change. My sump has had a good strike and not for the first time as the sump nut only had one original flat side and the pan had worn paper thin and cracked. I had a lovely replacement £17 from a zoner (sorry I forgot your name) 318 lower pan so a nice easy job.
When removing the bolts I notice a threaded swarf on one bolt and dad said straight away that it was a 'helicoil' and as he said when putting it back it wouldn't catch. I have put the bolt back with some loc-tight on the thread, but I'm now worried that I might get a leak even though I have only slightly nipped up the bolts with the same amount as they were when I un-done them as I was warned by the zoners. is it essential that I replace the bolt with a 'helicoil'?
Thanks.
One sump bolt not playing.
savagehenry
Tom_Maverick
is there enough meat on the bottom of the engine to drill it a size up and tap it and then drill a slightly larger hole in the pan lip? that might be a better option.. I have no idea what size the bolts even are on a sump..
if the original bolt was helicoiled and it came out with the bolt you should re-do it.. it's where someone threaded it in the past and you don't want it coming out...
savagehenry
Because it's a lower pan it goes into and 'open' hole if that makes sense. It's threaded into a 'tab' on the upper sump instead of being wound into the actual block.
I'm just hoping that I can do a re-thread with the new sump still on as I've just topped with fresh oil.
