Strabge question i know but do the e30s have different thickness of glass??
Reason i ask is that last year my drivers window was smashed on my touring and so i got a replacement glass but when i jet wash it it lets in water a bit and also hear wind whistling through when i drive... There's no glass in the lining of the door, i've checked already
Are some windows thicker than others???
The_Haywood
- miketemplar
I've checked the wholesalers and there is only one thickness of glass for normal e.30's, although M3's were thinner.
The_Haywood
aaah thanks for that mike really appreciate that... hmmmm must figure this out.... cheers though it's one thing ticked of on what it CAN'T be haha
- miketemplar
You're not far away, if you want I'll have a look at it with you. I'm between Bridgnorth and Ludlow.
kam-325i
- Contact:
I feel sorry for you !!!!!!!miketemplar wrote:You're not far away, if you want I'll have a look at it with you. I'm between Bridgnorth and Ludlow.
Haywood, you will need to adjust the glass using the mounts the glass sits in on the Mech....
- miketemplar
You're allowed you're misconceptions! Sad I know, but after 33 years fitting the damn things I thought I might help.
