Suspension Query
e30kid6
Post Wed Mar 21, 2012 9:15 am
Hi all,
Whats the deal with the different diameters on the front struts, which models have the certain size? etc.
I've been looking at coilovers, what is the general best for a 318i in your opinions and why?
Post Wed Mar 21, 2012 9:18 am
ross_jsy
Yours will have the smaller 45mm strut. 325i's, cabs and touring (and iS') have the larger 51mm strut.
What is your budget? Most cheap coilovers are rubbish and a decent shock/spring combo will be far better
e30kid6
Post Wed Mar 21, 2012 9:52 am
Okay thanks
I have a budget of about £600, and well I have a combination of Apex springs and dampers on the rear and Aprex springs with original dampers on the front. But the rear is sagging, so really my suspension just needs to be better and the front, lower.
ross_jsy
Post Wed Mar 21, 2012 10:03 am
I would recommend some eibach springs with bilstein dampners then.
You could go for the Gaz kit for a bit more, but I am unsure what they are like. The Gaz golds seem to be the lower end of the worthwhile coil over market and this set are a fair bit cheaper:
http://www.raceperformancemodified.com/ ... ilover-Kit
e30kid6
Post Wed Mar 21, 2012 10:27 am
Thanks for the help, I'll do some research.
