Fitting M Tech 1 Steering Wheel
sgaites
Post Tue Mar 20, 2012 7:16 pm
I've just bought a lovely M Tech 1 steering wheel for my E30, to replace standard 4 spoke.
It doesn't seem to sit properly though. Should the spacer stay in ? The splines are the same (fine).
Anyone done this ? I have searched online but can only find US sites where people swapped out the airbag wheel !
cheers
318isPMK
Post Tue Mar 20, 2012 8:38 pm
Airbag?
Sanchez
Post Tue Mar 20, 2012 8:39 pm
How doesnt it sit right?
bmw9818
Post Tue Mar 20, 2012 9:32 pm
sure the steering lock aint snagging it? it should just fit on unless the splines on the wheel are damaged...
mattrs
Post Tue Mar 20, 2012 9:39 pm
What spacer?
adit
Post Tue Mar 20, 2012 10:40 pm
as above, you do have the ignition key turned to position 1 don't you?
[quote="bss325i"]
sgaites
Post Wed Mar 21, 2012 6:44 am
No airbag. Steering lock is off...the old wheel pulled off easily. There was a spacer on the shaft, about 1/2 inch.
The mtech wheel just doesn't seem to engage on the splines.
suchy
True Zone Relic
Post Wed Mar 21, 2012 9:03 am
Yes you will need the collar, but don't know enough to advise on whether a different model wheel is what you have instead of an E30 one?
