Day 1 of suspension upgrade/refurb (now with photos)
PeteE30Tourer
Post Sun Mar 18, 2012 10:30 pm
Having bought all the bits I thought I needed and given a nice sunny day, I commenced my suspension overhaul/upgrade today.
The plan was to replace the springs with the Eibach set I bought recently and replace a number of other components whilst everything was apart. I've done a fair amount of mechanics before, but nothing like this, so it was a major project for me.
Today I started on the rear. Armed with the guide in the Wiki and some very helpful advice from others on here, I set about pulling apart the rear suspension. All went well apart from 4 bolts that hold the diff onto the rear subframe, which took me a long time to remove as they're difficult to get to and were pretty well seized. Unfortunately, they were equally difficult to replace due to problems re-aligning the holes and again access was tricky. None of the guides I saw said anything about these - only the one bolt that holds the diff mount, but I couldn't lower the diff enough with only this one removed.
The drop links were perished, so I removed them and I'll get new ones sorted tomorrow. I also tore an exhaust hanger in removing it.
Whilst the diff was down, I drained the oil and replaced it with 75W90.
Then I started on the front with light fading. Got one side lower wishbone off, but the other side (passenger) I haven't worked out as yet how to get the the nut that holds the long bolt in the middle of the wishbone. I've removed the AFM/air filter, but access is still very limited.
So, all in all, I'm pretty chuffed with my achievements so far. I can see I've got more difficult challenges ahead though, such as:
1. Getting the old lollipop bushes out of the holders, so I can fit the new ones (M3 ones on order from dealer), then getting these pressed onto the new wishbones.
2. Getting the struts out and changing the springs.
Questions so far:
a. I bought E36 Coupe bump stops, but I cant see where they fit at the rear (or the front for that matter). Do they go on the shocks somehow?
b. Cant remember what the other question was now!
Back behind an M20, but now I can hear it better.
andyp
True Old Skooler
Post Sun Mar 18, 2012 11:32 pm
ok the nut left holding the wishbone is not a problem with a few long extension bars put together bringing it higher than the engine,
as for the lollipops you will need a press really to get the old ones out and new in [ thats why i said about the ones ive got already in lollipops]
the top diff bolts sometimes go straight in and other times you have to wiggle the diff about a bit, they are always tight to come off thats normal,,
i take it you have a spring compressor to take the old springs out and fit the new, the nut on the top mount will be a pain to undo and tighten up, just use a cloth and pair of mole grips to grip the top of the shock between the spring while you undo and refit the nut.
i think i still have your number and will ring you tomorrow to see what you need for the exhaust before i send your parcel off incase i have the bit here.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Mar 19, 2012 6:28 am
Good stuff! If you come across any errors in the Wiki if you're using it as a reference, please let me know.
And I know what you mean about the diff; I lowered and raised mine about three times before I found the angle to make all the bolts line up.
Post Mon Mar 19, 2012 6:47 am
I've never took the Diff off without taking the beam and trailing arms all off in one hit - have you replaced the diff bush ?
Need to do this on my turd.
For the lollipop bushes and new arms don't feck around trying to do it yourself - there are all sorts of stories on here about using tyre soap, putting the bushes in the freezer first etc etc - don't bother - you still need gargantuan amounts of strength to get the lollipops onto the arms.
With a hydraulic press its a job thats done in a couple of minutes - take the new arms/bushes down to your local small garage and give them enough for a pint - job done.
They can use the new lollipop bushes to press the old ones out - just make 100% sure that they line the new bushes up correctly - there is an arrow on the bush which corresponds with a marking on the lollipop casting to align them.
PeteE30Tourer
Post Mon Mar 19, 2012 8:23 am
Thanks for all the helpful advice guys. One thing puzzles me about the lollipop bushes - do you put them on the wishbone first then put the lollipop over it, or vice versa? I have a friendly garage up the road, so they'll hopefully do this for me.
As for the diff bolts, I confess I left one of them out as there's no way it would go back in for some reason. I dont know if I crossed the thread in the casting - I changed the bolts over, so it wasn't them at fault.
I dont have enough extension bars to get to the point above the engine for that last elusive wishbone bolt, but I'll try to borrow one.
Andy - thanks for the offer on the exhaust mount - I'll PM you a photo of the one I need.
Post Mon Mar 19, 2012 8:28 am
You need to press the lollipop bush into the lollipop casting and then get the "complete" lollipop pressed onto the arm. Getting a garage to do it with a hydraulic press is the way to go - i struggled for most of a saturday morning and then gave up - garage did it in seconds.
G-Bear
Post Mon Mar 19, 2012 8:55 am
This all good to read. I'm currently collecting parts for a whole suspension overhaul. Good luck with it all. As for bushes, I'd definately follow capri_rob's advise and take them to a garage to get pressed.
clipper
Post Mon Mar 19, 2012 11:11 am
I did my lollipops on my own without taking the wishbones off the car.
I used a threaded cramp (big long one) with the one end ground down to fit into one of the holes in the wishbone. The other end behind the bush (already pressed into the lollipop), and gradually tightened it up to force the bush onto the arm, lubing it with tyre soap first.
The only problem was that the cramp kepy popping off as it was tightened but with a few helpers holding it in place it finally worked.
PeteE30Tourer
Post Mon Mar 19, 2012 12:28 pm
I did take some photos along the way, but forgot to download them from my camera. Will post them soon.
PeteE30Tourer
Post Mon Mar 19, 2012 8:14 pm
Photos as promised:
As the car was (original suspension), not quite level ground, so a bit misleading, but I'll take an identical shot when it's on its new springs so there can be a comparison like-for-like.
The box of tricks from Eibach:
Comparison of original and new rear spring:
Rear drop link knackered:
Diff mounting bush - I think this one is ok, so I didn't replace.
matt86
Post Mon Mar 19, 2012 8:33 pm
well done pete, I;m interested in this also, need to do this to my cab, was good talking to you today and finally meeting you. Good luck with the rest of the suspension/bushes overhaul.
Matt
PeteE30Tourer
Post Mon Mar 19, 2012 9:43 pm
Cheers Matt - and thanks again for the bootlid - well chuffed with that.
Watch this space.
andyp
True Old Skooler
Post Tue Mar 20, 2012 2:30 pm
ive just come back from the post office, should be with you tomorrow as i sent them 1st class :cry:
PeteE30Tourer
Post Tue Mar 20, 2012 2:33 pm
1st class service Andy! Many thanks. Top man!
PeteE30Tourer
Post Wed Mar 21, 2012 12:54 pm
capri_rob wrote:They can use the new lollipop bushes to press the old ones out - just make 100% sure that they line the new bushes up correctly - there is an arrow on the bush which corresponds with a marking on the lollipop casting to align them.
Haven't looked into this in detail yet, but assuming there are marks on both the bushes and the lollipop castings that can be aligned as you say, how do you ensure this then goes on the wishbone at the correct angle? Can you rotate them round once on, or do you need to ensure they're exactly right when putting them on? If it's the latter, I can see this might be tricky if the wishbone is removed from the car and done remotely.
rrs
Post Wed Mar 21, 2012 1:08 pm
The freezer trick does work, I left my m3 offset bushes in the freezer overnight and then pressed them into the lollipops using a 4" bench vice and I am pretty much as weedy as they come. To get the old ones out hacksaw and cold chisel then pressed onto arms with homemade "puller" and a few dobs of fairy liquid.
Post Wed Mar 21, 2012 1:40 pm
I tried exactly the method above/\/\/\ all it seemed to do was start to damage the bush as soon as any real pressure started to build up :cry:
Putting the arm on in a press and a socket over the metal ring where the arm pushes through eliminates the risk of tearing the bush.
rrs
Post Wed Mar 21, 2012 1:56 pm
Strange I had no problem at all, I am willing to admit this method might not be for everyone though.
schnaarf
Post Thu Mar 22, 2012 5:08 pm
rrs wrote:
I could be wrong, as I can't see the rest of the wishbone, but that looks like a right hand side lollipop bracket on a left hand wishbone?? Looks to me as though the two indents on the bracket are on the side facing the camera, which i think might be wrong.
Unless its just camera angle?????
rrs
Post Thu Mar 22, 2012 6:38 pm
I can see what your saying Schnaarf it does look wrong and it's a while ago now that I did them but everything was correct when it went back on the car, I can remember checking it all multiple times. :thumb:
Post Thu Mar 22, 2012 8:09 pm
All this messing about!
The easiest way and best is to use tyre soap on the end of the wishbone and the bush then use a socket on the inner metal part and hit them on with a copper hammer.
The tyre soap dries out after a while and the bush has settled which is what you want.
