I remember seeing a picture of an ajustable trailing arm that i think was either used on sjniers rally car or the e30 DTM.
does anyone remember where this is or have a photo of it?
i am curious as to how it works.
cheers,
Matt
Group a or DTM rear arms
randomspeedfreak
nickso
- Location: Go do that voodoo that you do so welllllllll!!
'88 e30 328i M52 track bint.
randomspeedfreak
thanks very much
WOW what a bit of kit eh!
struggling to understand what is going on on the rear trailing arms tho...im a bit slow without a diagram!
cheers mate
cheers mate
nickso
Yeh I don't get it either just from the pics. Would need to have them in my hand or a look on the car to get it properly.
randomspeedfreak
also off topic now but is that a rieger splitter on the front of your sig picture?
nickso
No it's a cheap ebay fibregash special. Think it's going in favour of an Is splitter this year.
randomspeedfreak
let me know if you want rid i like it - im having a think about which to go for with mine
cheers,
Matt
cheers,
Matt
nickso
It's not a great fit mate, only any use for a track turd or a steviebmw replica. Even then there's better options out there.
HairyScreech
Inner joint can be moved in and out for toe, the outer one has a vertical adjuster the arm to do camber.
Other than that its just a fabricated arm with the suspension mount above rather than at the rear.
The arb uses a stiff tube and blades which can be turned to give different spring rates by nature of the direction there bent in, when flat the rate is less and when 90deg to that they are full stiff.
