325i Sport Auto idle problem
Francoise
Post Fri Mar 16, 2012 8:42 am
Over the winter my car has not been used much as we have been working on the bodywork, but I have noticed when starting the car I have to hold the revs as it wont idle, also when cold it missfires, but when put in gear, as it is a auto the car runs fine, any ideas what I need to look for?
Tom_Maverick
Post Fri Mar 16, 2012 11:20 am
check or just replace your blue temp sensor on the top of the engine.. (I'm sure there's a sticky in the M20 tech section on motronic idling) that's the first thing to check.. then look for air leaks on the inlet side of the engine..
SHAZ325iSPORT
Post Fri Mar 16, 2012 11:44 am
could be your tps(throttle position sensor) which sits under your throttle body.
found that problem on alot of autos.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Mar 16, 2012 11:49 am
Tom_Maverick
Post Fri Mar 16, 2012 12:03 pm
thats it.. it's in the wiki.. sorry! I'm sure I'd seen a thing on idling somewhere!
pukar
Post Fri Mar 16, 2012 12:37 pm
happened to my auto and was the blue temp sensor...not too easy to switch though but sorted out the problem....(BTW, your decals have arrived :D )
Rtaylor2208
Post Fri Mar 16, 2012 12:55 pm
SHAZ325iSPORT can you details how to check it for an Auto as it has 6 pins and not the usual 3 and its not coverved in the wiki.
Francoise
Post Fri Mar 16, 2012 3:40 pm
pukar wrote:happened to my auto and was the blue temp sensor...not too easy to switch though but sorted out the problem....(BTW, your decals have arrived :D )
Thanks for all the advice will sort it out soon, looking forward to seeing the stickers Atul.
