This is a little odd, given i have had the car for more than 6 months.
Over the last few months i have put the amount of smoke from the tail pipe down to cold weather and the fact this isn't exactly a new car.
Now this is not black smoke, its very clean pure white smoke. its not burning oil, not over or under heating and no dodgy smells from the exhaust.
is this normal for a chromie?
White smoke
kolee
scjimbo
I would think its probably not smoke. Its probably steam. Check that your coolant levels are staying up. If not you probably have a head gasket gone.
M20's do seem to chuck out quite a bit of steam from cold - especially in cold weather - should clear pretty quickly as the car warms up though.
As above check your levels / check for oil & water mixing on the oil cap/dipstick.
If the levels are all OK and theres no mayo on the oil cap dont worry about it.
suchy
- True Zone Relic
Mine does a lot from cold and doesn't lose coolant/oil ever (touch wood) Always done it
this time of year there's plenty of steamers about of a morning !
+ a yard full of scrap turds
Burning fossil fuel produces large quantities of water - simple, basic chemistry.
All cars do this (except electric) and all will produce white smoke (water vapour, not steam) from the exhaust, until things warm up, and the water does come out of the tail pipe as (invisible) steam.
Quality cars, like BMW, tend to have more elaborate exhausts built from thicker materials than the mass market fodder, so their exhausts take longer to become hot enough to prevent the steam from combustion condensing into vapour before emerging, and older BMWs like ours tend to be thirsty on fuel, so produce more vapour than more economical vehicles.
kolee
Thanks for all the info.
My coolant level has dropped a little since i topped it up, but only about centimeter in three months, not enough for me to worry about it.
I only do relatively short journeys of 15 miles or so, so i guess the car spends more time cold than hot.
Don't top it up. In my experience, the 'level' mark for E30 coolant tanks is about 1cm too high, and they will always push out coolant until they stabilise at this lower level.kolee wrote:Thanks for all the info.
