e28 lsd
tommo325
Post Tue Mar 06, 2012 10:08 pm
Hi guys me again
Will an e28 m535 lsd fit and e30. I have read somewhere it will with a different back plate. can anyone shed some light on this for me
Post Tue Mar 06, 2012 10:15 pm
No, the E28 535's use a 210 "large" case diff and E30's use 188 "Medium" case and 168 "small" case diffs.
The large ones dont fit but some E28's use the medium case diff and can be use on E30's by swapping the back plate and output flanges for E30 ones.
tommo325
Post Tue Mar 06, 2012 10:22 pm
http://www.ebay.co.uk/itm/150770368100? ... 630wt_1185
This is the one i am on about and the ad said it will fit so was just checking
Post Tue Mar 06, 2012 11:00 pm
That's a clean diff!
In fact if someone said it was only a few years old, i'd be inclined to believe them!
But it wont fit.
318isPMK
Post Tue Mar 06, 2012 11:03 pm
can I ask a question... whats a Limited Slip Diff?
snakebrain
Post Tue Mar 06, 2012 11:31 pm
318isPMK wrote:can I ask a question... whats a Limited Slip Diff?
Can I ask if you've ever heard of Wikipedia? :) basically it lets the back wheels rotate at different speeds..
318isPMK
Post Tue Mar 06, 2012 11:36 pm
ive just jumped on.
Is that why I put wheel caps on my alloys at the weekend and now they are all in different positions
snakebrain
Post Tue Mar 06, 2012 11:38 pm
Yep.
ross_jsy
Post Wed Mar 07, 2012 8:50 am
Poor description of a LSD...
Essentially a limited slip will allow the wheels to rotate at different speeds like a normal differential in certain conditions and behave more like a locked differential in others. When you go round a corner, the inner wheel has to rotate slower than the outer wheel. If the diff was locked the inside wheel would skip and skid round the corner.
But in situations like hard acceleration or where one wheel has no traction, due to the nature of a differential it will send the power to the one with the least grip. Obviously not much good. This is where LSD's come in. When 1 wheel starts to spin it will lock the diff together to some extent to send power to both wheels. The way it does this depends on what type of diff you have. BMW's use a clutch type diff in which plates are pressed together with a spring. The diff will only slip when enough power is sent to overpower the clutch. A standard e30 diff has (had) 25% lock up when new iirc. That means when fully locked, the wheel that would normally get no power will receive 25% of the torque.
They are basically a traction aid and are very nice to have especially if you like to drive hard. They also make sliding the car around a lot easier as they minimise the risk of going into a tank slapper.
HTH
Post Wed Mar 07, 2012 9:22 am
318isPMK wrote:ive just jumped on.
What you need is a welder :)
Sjoerd320i
Post Wed Mar 07, 2012 10:42 am
The diff show there will fit your car.
You only need the outpuflanges from an e30 and the backplate.
Jos
Post Wed Mar 07, 2012 10:49 am
329iturbo wrote:The diff show there will fit your car.
Could you elaborate a bit please, I have the same diff sitting pretty in my partsbin with 60k on it. I looked at this a few years ago and didn't think the splines matched?
'94 e36 tree climber
Jos
Post Wed Mar 07, 2012 11:03 am
ah nevermind, I have an e23 one. Yep it looks like the output flanges are swappable
Post Wed Mar 07, 2012 11:50 am
Almost certainly even more than he could imagine ! :eek:
Post Wed Mar 07, 2012 1:19 pm
I had a bid on that E28 scrap, there are a lot of perverts about looking at the bid history :o
