Help please
biggill
Post Sun Mar 04, 2012 9:38 am
I have recently had my head skimmed and purchased a new head gasket, put it all back together fired it up, turned over first time.
How ever when running the engine trying to bleed it i noticed the engine was getting hot the fan was kicking in but inside the car i was getting cold air and the temp needle is not moving from cold also the water seems to be pressurizing, I have checked the thermostat it does open when it gets hot how ever still got the same problem.
Has anyone come across this also what would you recommend my next check would be.
My car is a 325i convertible.
sweep
Post Sun Mar 04, 2012 9:42 am
Sounds like a air lock..how did you fill the coolant up? just via the header tank?
biggill
Post Sun Mar 04, 2012 9:46 am
Thats what i thought i cant seem to find it, yeah filled it by the header tank, is there another way? what would you suggest?
sweep
Post Sun Mar 04, 2012 9:54 am
Open the 8mm headed bleed screw on top of the thermostat housing,take the radiator top hose of at the rad end fill with coolant via the hose so that the engine is getting filled up untill coolant is coming out of the radiator itself ,then put the hose back onto the rad,top the headertank up to the ridge (facelift car) then put the heater on full on the warm setting then start the car up leave to run keeping a watch on the temp guage ad a constant small amount of revs untill a steady stream of water is coming from the stat housing without air bubles in,and make sure there is a steady flow (when reving) from the small pipe from rad to header tank.once this is complete the heater should be good ,nip the bleed screw back up!
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Mar 04, 2012 9:55 am
put "bleeding M20" into the search box, and you'll find plenty of posts detailing how to do it. These engines are notoriously hard to bleed.
Post Sun Mar 04, 2012 10:03 am
What was the problem that prompted you remove the head in the first place? Head gasket failure on a 325 is relatively rare, compared to a cracked cylinder head, which can give similar symptoms.
Did you have the head checked for cracks?
You have all the symptoms of an airlock, except that usually the temperature gauge moves very quickly hard into the red. Are you sure you've reconnected the gauge sensor.
You fill the cooling system by the header tank, but it needs to be done slowly and with care, and importantly, with the car level or up at the front.
The easiest way to release the airlock, if this is the problem, is to pull the header tank overflow tube in through its hole in the inner wing, remove the top heater hose on the bulkhead, place your hand flat over the top of the header tank neck, put the free end of the overflow tube in your mouth, and blow gently. When coolant is emerging from both the heater hose and the stub pipe, push the hose back on.
biggill
Post Sun Mar 04, 2012 10:29 am
Brianmoooore wrote:What was the problem that prompted you remove the head in the first place? Head gasket failure on a 325 is relatively rare, compared to a cracked cylinder head, which can give similar symptoms.
My cam was worn so i replaced the cam then i thought i would get the head cheacked and was told it needed to be skimmed. I'm sure the engineering company would have told me if the head was cracked.
I will double check the gauge sensor, but would that still affect the heat in the car?
andyp
True Old Skooler
Post Sun Mar 04, 2012 10:43 am
as said above but also turn the heater on and in the hot position when bleeding, they can be a foooker to bleed sometimes
biggill
Post Sun Mar 04, 2012 10:50 am
andyp wrote:as said above but also turn the heater on and in the hot position when bleeding, they can be a foooker to bleed sometimes
I have done this, i agree with you foooker is the word i would use, been trying to sort this for the last 4 days. A pain in my backside lol.
andyp
True Old Skooler
Post Sun Mar 04, 2012 11:40 am
where abouts are you
Post Sun Mar 04, 2012 1:05 pm
your heater matrix could possibly be blocked.
what i did with my m50 was to jack the front of the car up [or on small ramps] so the water in theory flows to the matrix.fill from top hose direct into engine till the rad fills up.Once full just inside the rad filler hole you'll see a square return hole,cover this by pushing a finger against it and squeeze the bottom hose until no air bubbles are left.You need to keep topping up with coolant here.
when no bubbles are left replace filler cap and start the car till the thermostat opens and the pipes are warm now you should have some heat at the heaters.turn off let cool for 5 mins then repeat the cover rad hole and squeeze pipe,this should see the last of the air bubbles go and good heat etc .
if by now there is no heat feel both pipes the go to the matrix,if one is hot and one is cold i'd be looking for a new matrix .
biggill
Post Sun Mar 04, 2012 3:39 pm
andyp wrote:where abouts are you
I'm in ashford middlesex
biggill
Post Sun Mar 04, 2012 3:44 pm
I shall be trying again tommorow, will let everyone know the out come.
If any other idea's pop up feel free to let me know.
Thank's
biggill
Post Wed Mar 07, 2012 9:13 pm
biggill wrote:I have recently had my head skimmed and purchased a new head gasket, put it all back together fired it up, turned over first time.
Right update so far, did everything to check if i had an air lock it turned out to be a blocked radiator so i replaced the rad and all is fine i have heat inside the car bleeded fine.
How ever my temp gauge is still not working i have tried shorting the brown plug at the thermostat housing and it did not move i have tightend the brass nut at the back of the cluster, i have tried another cluster and still nothing.
Can anyone shed any light?
Thank's Gill
kam-325i
Post Wed Mar 07, 2012 9:14 pm
connector underneath the inlet manifold ?
