got the touring on the ramp today and there in desprate need off some new bushes as there past it so thought a would poly bush them
anyone recommend any brands
thanks
anyone recommend rear subframe bushes
badassyas
For a road car, genuine or lemforder bushes with danthe inserts will be more than adequate
Dezzy
- CR24v it's a lifestyle
THIS.badassyas wrote:For a road car, genuine or lemforder bushes with danthe inserts will be more than adequate
For a road car rubber is the best way forward
+1 , Poly bushes are shite,Dezzy wrote:THIS.badassyas wrote:For a road car, genuine or lemforder bushes with danthe inserts will be more than adequate
the one's you are taking out have probably lasted 20+ years they can't be that bad ?
jmccall85
cheers guys
so just standard bushes then !
are they staright forward to do any tips in fitting them
thanks
thanks
Dezzy
Unless you have the correct tool, Its a rear beam off job. This can be tricky.
leeparkes
They can be a right bastid.
You can do it without the tool with the beam on the car.
jmccall85
my mate did laugh when a asked if he had done a set before
it should be fine we will find something in the garage to make some sort off a tool
G-Bear
have a look here..badassyas wrote:For a road car, genuine or lemforder bushes with danthe inserts will be more than adequate
http://www.e30zone.net/modules.php?name ... c&t=208635
He still has a few sets left, I ordered a set off him the other day..
jmccall85
will get a look at theseG-Bear wrote:have a look here..badassyas wrote:For a road car, genuine or lemforder bushes with danthe inserts will be more than adequate
thanks
BATTS91
i got a set of those bush fillers on the last group buy havent fitted yet but everyone whos used has reccomended them good price too
Grrrmachine
- E30 Zone Wiki / Team Member
All Bush info is in the Wiki:
http://www.e30zone.net/e30zonewiki/index.php/Bushes
If the name of the bush is in blue, then there's an article on how to fit them.
