318is Induction?
samuraibaz
Is fitting a k&n cone filter a simple case of unplugging & removing airbox & fitting k&n or is there something else i need to do about the electric screw in wiring that went onto the airbox???
kam-325i
Yes, leave it connected. Thats plugged into the AFM......samuraibaz wrote:is there something else i need to do about the electric screw in wiring that went onto the airbox???
You should not be unplugging anything electrical to fit a Cone filtter.......
I personally would not bother with the cone filter, just leave the air box alone and get a panel filter.
rix313
Wouldn't bother with the cone, makes it worse. Get an uprated replacement panel filter and keep the airbox.
samuraibaz
cheers guys airbox goes back on with performance panel filter in the tomorrow gave it a service today & fitted a k&n some1 gav me & car seemed flat hence the post thanks again
