front eing removal convertible
matt86
Post Sat Feb 25, 2012 9:16 am
Hi got up early today to do some work to my convertible, fit leather seats, chrome deep dish bbs replicas and change the front wings, just wanted to make sure how they come off. 5 bolts under the bonnet on top of wing and then what else is needed. There must be a bolt or 2 at the bottom right? Do inner plastic arch protectors or bumper need to come off, I assume not by looking at it.
Matt
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Feb 25, 2012 9:26 am
matt86 wrote:5 bolts under the bonnet on top of wing and then what else is needed. There must be a bolt or 2 at the bottom right? Do inner plastic arch protectors or bumper need to come off, I assume not by looking at it.
Can you take some pictures while you're doing it, for the Wiki?
IIRC, there's one bolt at the front (under the headlight, bolts to the front valance), there's two inside the arch bolting to the bulkhead, there's one clip for the arch liner going to the wing, there's one or two bolts at the bottom lip joining it to the sill, and there's the bumper mounting clip bolt, behind the bumper (meaning the bumper has to come off.)
This is from memory of a facelift car; I have no idea for a chromie. Just make sure you fit some sealant to the top of the wing, and get the arch liner secured, or you'll end up with this:
Post Sat Feb 25, 2012 9:31 am
you need the arch liner out to take a wing off. its all 8mm bolts with one torx.
theres 1 at the very bottom of the wing and 2 behind the arch liner - nobbas often don put these back on. hence you see pics of e30's with the wings off and the arch liners still fitted.
Post Sat Feb 25, 2012 9:36 am
Bumper off, and bumper brackets
Dezzy
CR24v it's a lifestyle
Post Sat Feb 25, 2012 12:18 pm
Isn't there are bolts to remove with the door open looking through gap?
adit
Post Sat Feb 25, 2012 6:41 pm
no need to open the door Dezzy, but there are two 8mm screws at the back of the front wheel well, securing the wing to the A post area.
Matt: i removed a mauritius N/S/F conv. wing yesterday, all good, if you're interested
[quote="bss325i"]
Dezzy
Post Sat Feb 25, 2012 6:42 pm
I've always done them with a long extension with the door open :o:
Post Sat Feb 25, 2012 7:18 pm
You cant get to them through the door mate, they screw in from the front to back, so the arch liner has to come out
Post Sat Feb 25, 2012 7:23 pm
Did i already say that?!
Post Sat Feb 25, 2012 7:29 pm
Say what
Dezzy
Post Sat Feb 25, 2012 7:57 pm
DanThe wrote:You cant get to them through the door mate, they screw in from the front to back, so the arch liner has to come out
I've only removed them from the red 4 door mate. The nut heads were defos on the door side?
Must have been put on wrong by a previous owner?
Post Sat Feb 25, 2012 8:32 pm
100% wrong by the previous numpty Desmond
Dezzy
Post Sat Feb 25, 2012 8:35 pm
Simon13 wrote:100% wrong by the previous numpty Desmond
That explains it then. As you were, nothing to see here. winkeye
MARKYMARKY
Post Sat Feb 25, 2012 8:36 pm
Done one on my chromie today,one of the 8mm bolts at the back was a real bitch!!!
But she looks much better now :D
George
Post Sun Feb 26, 2012 11:36 am
Are prefacelift and facelift cab wings interchangable?
adit
Post Sun Feb 26, 2012 6:25 pm
yes
[quote="bss325i"]
tonybtonyb
Post Mon Feb 27, 2012 1:19 am
got there in the end winkeye
