lowering your car and negative camber!
g57yle
- Boost Junkie
did everybody know that once you lower your e30, not only do you end up with negative camber but your rear wheels also toe aout. and they both induce premature inner tyres wear!
Dan318-is
Every steering angle known to man goes out the window when you lower your car, not just camber and toe in/track.
There is generally more strain on the castor/SAI angles although most cares iv been told make allowances for this
But your point arises why you should never just use springs to lower the whole car!
g57yle
- Boost Junkie
i have realised this and im trying to resolve this by making a fully adjustable rear axle but then i get confused with the front!
Demlotcrew
Good luck to you! (you'll need it if you get confused by the front)
Andrew
Andrew
Moofles
huh? are you saying just using springs causes excess negative camber? that ain't right is it - shocks, and coilovers, and stuff doesn't correct the camber - it's the design of the trailing arms, the angles at which they're attached to the chassis, you need to change that (or the angle at which the hub is attached to the trailing arm)318-is wrote:But your point arises why you should never just use springs to lower the whole car!
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig
- http://img52.imageshack.us/img52/2652/funnyface8eg.gif
My old sig
Paul325i
It's a very well known fact, you can correct it with offset bushes.g57yle wrote:did everybody know that once you lower your e30, not only do you end up with negative camber but your rear wheels also toe aout. and they both induce premature inner tyres wear!
mrLEE30
anything lowering your car will affect the all angles.
You could correct the camber etc with off-set bushes if you used just springs!! only bad effect of just springs is that it pre-maturely knackers the stock absorbers or/as they operate in a range they are not deisgned for, that is why springs alone dont produce the same handling effect to shorter shocks and springs, and at the top end of the market the coilovers, but as far as i am aware the coilovers are only for the front suspension anyway on an E30??
mrlee
mrlee
Ziggy
It is... but what's not so well known (by me anyway!) is where you get these bushes from!Paul325i wrote: It's a very well known fact, you can correct it with offset bushes.
mrLEE30
I thought they were brushes and you got em from Body shop!??
could be wrong though!
i would imagine a call to one of the better tuning shops should set you straight, look in the back of PBMW in the ''yellow pages'' and find a good on near you.
you can also have them custom made
Dan318-is
I know it does but using just springs is cheapoMoofles wrote:huh? are you saying just using springs causes excess negative camber? that ain't right is it - shocks, and coilovers, and stuff doesn't correct the camber - it's the design of the trailing arms, the angles at which they're attached to the chassis, you need to change that (or the angle at which the hub is attached to the trailing arm)318-is wrote:But your point arises why you should never just use springs to lower the whole car!
why are we moaning? we need more neggy camber to get these boats to handle somewhat.
So a newer bloody mondeo doesn't make u look stupid. Don't lower 60mm and your tyres will last!
massive
Lots of places sell camber correction kits. Demon tweeks do them for Ԛ£15/Ԛ£20.
karlp
MrLee - You can get rear coilovers - I have them on my E30 M3 (LEDA)
Getting camber adjusters is easy (again I have both front and rear). The real problem is finding someone who has the knowledge and is willing to set them up for you (race car prep facilities will do them).
If you want them speak to Moseley Motorsport.
Karl
Karl
panesar_e30
negative camber rocks!
Hyperion
Hi guys, as some of you will know, i have just dropped my car 40mm. Here is the results of an alignment. As you can see things are off....
Front: caster +8 28' +8 40'
camber -1 52' -2 20'
toe +0 8' +0 34'
total toe +0 42'
rear: camber -2 28' -2 12'
toe +0 22' -0 16'
total toe +0 6'
now thats what i call off, anyway, gonna have an alignment hopefully this weekend and i will put up the new angles.
PS: for all the guys out there who dont know what toe in , camber , caster is, here is a cool website.
http://www.ozebiz.com.au/racetech/theory/align.html
toe +0 8' +0 34'
total toe +0 42'
toe +0 22' -0 16'
total toe +0 6'
