heaters not working on m3
E30_Maniac
Fri Feb 17, 2012 9:37 am
hi, my heaters have stopped working on my m3, any suggestions to what it maybe
thanks
Demlotcrew
Fri Feb 17, 2012 9:40 am
Where are you located?
It can be a number of causes, its best that its looked at by a professional that would not over specify whats actually needed to be done because they have no diagnostic skills.
Andrew
Fri Feb 17, 2012 9:43 am
First question is: Do you mean heater or heater fan? They are completely different things.
harry_p
has the fan stopped working, or does it still blow but only cold air?
cheers,
harry
E30_Maniac
Fri Feb 17, 2012 11:06 am
the heaters inside the car
kundiboy
Fri Feb 17, 2012 11:10 am
E30_Maniac wrote:the heaters inside the car
People know its the heaters in the car.
What people are asking is:
- are the interior heater fans working?
- is there any hot air coming into the cabin?
1988 Diamond Schwartz E30 M3
E30_Maniac
Fri Feb 17, 2012 12:24 pm
interior heater fans wont work. will not de-mist. when you turn the speed of the heaters up you can feel a very very very tiny bit of air, however not enough to de mist or keep u warm
Fri Feb 17, 2012 1:30 pm
E30_Maniac wrote:interior heater fans wont work. will not de-mist. when you turn the speed of the heaters up you can feel a very very very tiny bit of air, however not enough to de mist or keep u warm
That's the fan then, and nothing to do with the HEATer. Without this info., this thread would have gone off on an irrelevant tangent.
Do the electric door mirrors work?
E30_Maniac
Sun Feb 19, 2012 2:49 pm
alll the electrics work fine.
Sun Feb 19, 2012 6:12 pm
In that case, the fan motor has probably seized after twenty years without maintenance, possibly blowing fuse 20 as well.
Usually recoverable if the motor is removed and serviced.
