Anyone use their E30 for towing?
Von_Thrash
Fri Jan 27, 2012 7:47 pm
Are they up to it? I've pulled a trailer which weighed 470kg alone with most of a 3 foot high brick chimney in it, my 325 seemed to cope ok, still braked alright etc. Im hoping to pull a caravan chassis trailer (300kgs?) with a stripped out and lightened mk1 fiesta on it (700kg?). . . .
So, i suppose what im asking is, is it safe to pull a ton with an E30?
_Jay_
Fri Jan 27, 2012 7:57 pm
Towed an astra in my 320 before. Slightly different, but its probably around the same weight. Car had no problems what so ever.
kam-325i
as long as it is a braked trailer, it should be ok.........
mrLEE30
Fri Jan 27, 2012 8:09 pm
Auto or manual? If auto then do not allow it to go into overdrive, I.e keep it in a low gear/higher RPM otherwise can burn the clutches.
Fri Jan 27, 2012 9:05 pm
I've towed well over a tonne thousands of miles around western Europe with the red touring in my sig. I've also done a few hundred miles towing a drop tailed trailer around England with other E30s, the odd E36, and on one occasion, an E34 on it. That combo must have been two tones.
Never had any problems!
rhubarb
Fri Jan 27, 2012 9:08 pm
Yep, used my 320i touring(manual) to tow my caravan, which weighs approx 800kgs..
no problems at all :)
Von_Thrash
Fri Jan 27, 2012 9:20 pm
All very encouraging :) thanks chaps. The car is a manual, and about to get all its rear bushes replaced, so should be up to the job. . . . I promise to get pics of the forthcoming jacknife calamity . . .
Sat Jan 28, 2012 10:03 am
your not supposed to tow anything over the actual wieght of the car? So 1 ton will be ok as a touring is about 1250.
A 325i auto will happily pull another e30 along i've done it several times!
mr_dink
Sat Jan 28, 2012 10:07 am
Also bear in mind that depending when you passed your test you may need to pass another test to tow over 500kg.
Sat Jan 28, 2012 10:22 am
Simon13 wrote:your not supposed to tow anything over the actual wieght of the car?
There's all sorts of recommendations, but nothing actually written into law per se, until you reach 3.5 tonne GTW.
mattycoops43
Sat Jan 28, 2012 11:31 am
There's all sorts of laws and regs now. I can't keep up with it all, but I thought it was something like a max of 75% of the towing vehicle weight?
1990 325i se "weinrot"-How did they know?
mattycoops43
Sat Jan 28, 2012 11:32 am
kilrone
Sun Jan 29, 2012 2:55 pm
I towed an e34 535i over a distance of 450 km the car is more than up to the task. just take it easy, they can feel a little nervous with a lot of weight.
Gortour
Mon Jan 30, 2012 8:59 pm
I've had an E30 convertible on a trailer on the back of my 318I auto Touring.
Also had EWOK on a towrope behind it too.
