VIN number
oze30
Post Wed Nov 02, 2005 11:59 am
Can someone please post a pic of where there VIN number is spossed to be? I can only find the plate rivetted to the crossmember above the right headlight assembly!!
Post Wed Nov 02, 2005 12:06 pm
if you look where the rubber seal is around the bulkhead below the wipers, need the bonnet open, there is a VIN number stamped in there mate
massive
Post Wed Nov 02, 2005 12:14 pm
Give me the Reg and i'll save you getting your hands dirty
oze30
Post Wed Nov 02, 2005 6:53 pm
I checked between windshield and bonnet. All I got were numbers, no letters! Is this normal?
kidsinister
Post Wed Nov 02, 2005 8:17 pm
The VIN will be on that plate over the headlight.
If you've no VIN on the bulkhead under the screen, it could be a re-shell.
Should also be on the V5, if you've got it? :wink:
oze30
Post Thu Nov 03, 2005 10:04 am
checked, they all match, BUT i don't have any letters like it says on one of the american sites just numbers. Does this mean I have t
o go into a service dept and find out?
JOSEMI
Post Thu Nov 03, 2005 10:18 am
Hi Colin,
I would make sure - just in personal interest - that the VIN number you have in the shell matches the V5, as that would indicate that the chassis has always been the same (someone correct me If am wrong). Otherwise, I don't think why it should be a problem.
Are you in UK ??
Jose
boomer
Post Thu Nov 03, 2005 12:18 pm
www.realoem.com
type the last seven numbers in and it will tell you where and when your car was built - if the vin number only has numbers digits it may be an SA import
oze30
Post Thu Nov 03, 2005 1:43 pm
hey.. Thats a cool site!!
Says mine was built 12/1988. And you can click another button and it will browse the parts list for your car!
Wicked!
Oh.. It is a european model, not SA. But odd how there's no letters! 8O
boomer
Post Thu Nov 03, 2005 1:49 pm
mine was built 02/89 and its only got numbers, and it was allegedly built as a 2 door - but i've got history going back to 91 saying its a 4 door.
All i can think of is:
data entry c*ckup
customer changed their mind during build
reshell
I agree it is a bit odd but even the stealers didn't blink an eye when i ran the number past them - just muttered something about the bad old franchise days :D
