Painted rear beam & New brakes
m_jermyn
Tue Dec 27, 2011 1:54 pm
Been busy getting the odd job done on the E30...
I bought a spare rear end and started work on it..
Rear end work...
Paint stripped and wire wheeled (this is a bastard job.. BMW in their wisdom covered everything in wax to stop corrosion...) Not even paint stripper gets through this stuff
Caster/Camber correction klt..
Got this kit off Danthe (thanks mate) now just have to file out the holes.
Add a little bit of paint.... What do you think of the colour :D
I also was suffering some massive brake shudder (would shake the column real violently under heavy braking So I bought some nice new front rotors.. (rears to come with rear end)
Pleased to say that the brake shudder has gone...
nickso
Tue Dec 27, 2011 1:58 pm
You should've upgraded the ARB mounts at the same time as the camber plates. :P
'88 e30 328i M52 track bint.
m_jermyn
Tue Dec 27, 2011 2:48 pm
Only joking with the colour of the rear end...
AS IF I WOULD DO IT IN YELLOW!!
Thats etch primer you see in yellow... Black all the way :D
topcat56
Tue Dec 27, 2011 3:37 pm
how hard is it to change the four bushes where the two rear control arms attach to the rear beam. do you have to drop the whole beam to do this or can it be done on the car. thanks
sorry for hijacking thread
Tue Dec 27, 2011 5:50 pm
You remove the trailing arms to change the trailing arm bushes :wink:
Nice job Mike :cool:
Tue Dec 27, 2011 5:58 pm
i like that jig thing 8)
bigredbmw
Zone Supporter
Tue Dec 27, 2011 6:04 pm
am doin mine the next few weeks the same
Jim320i
E30 Zone News / COTM Team
Tue Dec 27, 2011 6:05 pm
Looking good fella! Should have polished them up and laquer'd them! winkeye
What paint did you use? I know everyone goes down the powercoated route but these look just as good. :cool:
suedenim
Tue Dec 27, 2011 6:36 pm
Looking good! Inspiration for me as I've got this lined up for the new year.
nickso wrote:You should've upgraded the ARB mounts at the same time as the camber plates. :P
What does this involve and what are the benefits?
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Green
Tue Dec 27, 2011 7:21 pm
m_jermyn wrote:Only joking with the colour of the rear end...
Looking Beaaaaaautiful! I hammerited mine but wish I did a little more now.
nickso
Tue Dec 27, 2011 8:03 pm
suedenim wrote:Looking good! Inspiration for me as I've got this lined up for the new year.
There's a pic here......
http://www.e30zone.net/modules.php?name ... t=arb+tabs
m_jermyn
Tue Dec 27, 2011 10:43 pm
Painted them in 2pak...... Same stuff you paint cars in..
Cost me nothing to do :D
kam-325i
Tue Dec 27, 2011 11:18 pm
topcat56 wrote:how hard is it to change the four bushes where the two rear control arms attach to the rear beam. do you have to drop the whole beam to do this or can it be done on the car. thanks
You could change the trailing arm bush's without dropping the ream beam, but you would have to remove the rubber petrol filler pipe where it joins the tank, as the pipe stops you removing the bolt on the offside.
suedenim
Wed Dec 28, 2011 7:19 am
Thanks nickso!
