no to bendzie przejebane heheGrrrmachine wrote:Get a wire cup on a powerdrill or angle grinder and get all of the blister off, every last dimple.
If the metal is just a little pitted, then you can get away with a rust treatment, filler, primer and paint. In which case, spray on some Dinitrol RC900, let it dry, key it with wire wool and then start the filler process.
If you've got a pinhole though, you're going to have to cut the metal out, because it'll be rotten on the inside too and it'll just grow and grow and grow.
i might drop it off at a polish body work shop see how much they would chargeRtaylor2208 wrote:Looks to me like that may need cut out. But only way to know is to grind it back and see if its good underneath.
Painting a car at this time of year is pretty much a no no, unless you have a heated garage to work in.
Will you be attempting this yourself?
I agree with all of the above.harry_p wrote:It's quite a big bubble, there's a fairly high chance it will leave a few pinholes when cleaned up, which means the rust will be spreading allong the inside too.
Best option would be to chop a piece out of a car that's being scrapped and get that welded in.
Just about any treatment or rust killer a bodyshop uses will only buy you a bit more time, it'll never properly cure it.
i know of a paint shop local to me i can get it for you and post if you want?Green wrote:Bit of a hijack but where's the best place to get rattle cans for a quick fix?
I need dolphin grey but halfords don't mix it up at all and can't think of anywhere else really
NoJozi wrote:It's great stuff! Did you cover it over with cling film so it doesn't dry out?
