E30 quick fixes....
pukar
Wed Sep 07, 2011 3:11 am
so many e30 problems are common but take too long to fix or too much money to investigate or fully sort out, so here are some quick fixes i thought up for the masses for common e30 problems.....
whining diff? - turn up the stereo
water in footwell? - wear flip-flops
(...any other suggestions? winkeye)
sunnyr83
Wed Sep 07, 2011 6:42 am
Hidden rust issues- Sell it for top dollar as 'rust free'
Ajsingh
Wed Sep 07, 2011 6:56 am
Not idling properly?
Tune the AFM to run richer
E30 Crazy!
Wed Sep 07, 2011 7:02 am
Blowing Exhaust ?
Aldi bean can & Jubilee clips FTW :D
cee
Wed Sep 07, 2011 11:06 am
capri_rob wrote:Blowing Exhaust ?
WINNING
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Ranchero
Wed Sep 07, 2011 11:07 am
There are few things that can't be fixed with a bit of gaffa.
cee
Wed Sep 07, 2011 11:11 am
Ranchero wrote:There are few things that can't be fixed with a bit of gaffa.
Mine's held together with electrical tape. But Gaffer/Duct tape would work better...
pukar
Wed Sep 07, 2011 11:27 am
battery keeps draining? - always park on a hill
handbrake not working? - never park on a hill
Sanchez
Wed Sep 07, 2011 11:30 am
Always carry a mixed bag of tie wraps.
Jim320i
E30 Zone News / COTM Team
Wed Sep 07, 2011 11:32 am
pukar wrote: whining diff? - turn up the stereo
Turning the stereo up also works for my whining fuel pump :cool:
Dont drive in the dark either when your bulbs are out :o:
Thats me just being plain old lazy and not changing them though
Wed Sep 07, 2011 11:58 am
Didn't someone (smithy318i, IIRC) use their windscreen washer pump as a temporary replacement for when his fuel pump packed up?!
skipunda
Wed Sep 07, 2011 12:22 pm
wacking the top of the dash for the temp needle
Chris
Duke137
Wed Sep 07, 2011 12:33 pm
Broken drivers door lock, climb in through passenger side
Stu_Bee
Wed Sep 07, 2011 12:48 pm
Drivers side electric window motor jammed/sticking? Open door and slam it while holding the window switch down. :o:
cee
Wed Sep 07, 2011 12:50 pm
As above but passenger side. Have to hold down the 'down' button and tap the 'up' button to make it go down :mad:
Quaser
Wed Sep 07, 2011 12:53 pm
Water in Boot - Drill a hole!
Windows not comming down/rear window not demisting - smash it!
Engine overheating/viscous fan packed up - open bonnet so front is raised and drive faster - more cooling!!!
Wed Sep 07, 2011 12:56 pm
Quick fix = Petrol and matches. Sorted.
Tom_Maverick
Wed Sep 07, 2011 1:10 pm
I had a trans-am with the bottom of the doorcard removed and a 15mm spanner in the centre pocket.. if you wanted the drivers window open you had to hold down the switch and tap the motor with the spanner.. I spent a good few thousand on the engine,drivetrain and having the paint sorted out.. never did fix that window though...
Wed Sep 07, 2011 4:18 pm
Noise through the steering column - blob of Blue-Tac behind the BMW badge does the trick!
Barx325i
Wed Sep 07, 2011 4:31 pm
full lock & find the rev limiter in 2nd gear - boredom / anger issue fixed
Ajsingh
Wed Sep 07, 2011 9:23 pm
Manual sunroof winder keeps falling down.... Bit of blue tac and it stays in place
E30 Crazy!
Wed Sep 07, 2011 9:27 pm
got 4 doors, scrap it :)
mercdriver
Wed Sep 07, 2011 9:32 pm
Ball joint - on removal the nylock bolt thread facked?...Pack it with washers and nip it up for now :mad:
Shouldn't be admitting to actually doing that! :D
I'll check with the manager
Barx325i
Wed Sep 07, 2011 9:39 pm
mercdriver wrote:Ball joint - on removal the nylock bolt thread facked?...Pack it with washers and nip it up for now :mad:
in fairness there's very little effort transferred via that assy
gravitational resistance vs spring load will overcome any issues unless you're aggressively rallying it, like me winkeye
mercdriver
Wed Sep 07, 2011 9:44 pm
I should get a picture - there must be 20 washers or more in there! Its only being moved now and then at my house and i've got a new ball joint for it to press in when i can be arsed to do it!
mercdriver
Wed Sep 07, 2011 9:47 pm
Not only did Rob use the cylindric tin - he even bodged the lid in!! :D
Joe-318i
Wed Sep 07, 2011 9:49 pm
skipunda wrote:wacking the top of the dash for the temp needle
find that works well for the petrol needle in mine winkeye
'83 320i chromie
'86 316 tech 1/M20B25 conversion
'91 318is touring
'87 chromie M10 rightness
Joe-318i
Barx325i
Wed Sep 07, 2011 9:51 pm
just heat the strut assy a little and it'll grip on like a koala, good for 80+k
mercdriver
Wed Sep 07, 2011 9:54 pm
You nutter :D
Barx325i
Wed Sep 07, 2011 10:05 pm
yes
A18RPF
Sat Sep 10, 2011 1:22 am
PAS pump screaming on cold starts? Always park with a straight exit
Sat Sep 10, 2011 7:02 am
To be fair I can't claim this as my own work - my best mate did this epic bodge to his Mitsubishi FTO - could quite easily be done on an E30 though :D
DavieP
Sat Sep 10, 2011 9:23 am
Brake sensor warning light on - cover with a bit of black electrical tape. More warning lights on - use a longer bit of tape :teehee:
Dave in Torquay
corkie
Sat Sep 10, 2011 6:18 pm
ariel not working-use a coat hanger
intermediate wipers not working-keep on full or fully off
:D :D
e30
Sat Sep 10, 2011 10:30 pm
Glovebox torch knackered or missing? Just remove the centre console and there's sure to be one lying underneath.
