And my girlfriends house rabbit shared the sentiment.
Hi Charlie. The pictured parts are the cam & crank sprockets, idler sprocket, timing chain, upper & lower guides and both tensioner pads. The parts are standard and as far as I know cannot be upgraded. Not pictured is the actual chain tensioner, the stock item can be upgraded to the E36 or E46 item.charlie_ogden wrote:Forgive my dumbness is that the timing chain and tensioners? Did you stick with the s14 ones or did you go for the upgrade?
Charlie
That part was the long tensioner pad (on the right, third from top in pic) which was £225+vat.leeparkes wrote:![]()
What was the most expensive item in that pile?
BooDan320is wrote:That part was the long tensioner pad (on the right, third from top in pic) which was £225+vat.leeparkes wrote:![]()
Dan320is wrote:..............especially when your car has an S14![]()
Thank you Dan,DanThe wrote:You got a major dry bumming there![]()
Just think, you would be well on your way to a proper engine with that sort of money
The S14 is a proper lump..Dan320is wrote:Thank you Dan,DanThe wrote:You got a major dry bumming there![]()
Just think, you would be well on your way to a proper engine with that sort of money![]()
You're right though.
