60/40 whats it like to live with?
Cypriotgeeza
Wed Aug 17, 2011 1:17 pm
Ok soon is time for my suspension overhaul and im also considering getting myself some springs to lower it,
Now on here Ive seen alot of people go for 60F/40R for both looks and handling benefits..
just wondering if 60mm drop is a bit much for a car with the sump so low?
If anyone has any dropped in this way could you give me some pros and cons please? or anyone who has a different set-up your advice is welcomed!
Thanx in advance for the replies peeps :thumb:
Check my M30 build threads:
Topblag
Wed Aug 17, 2011 1:25 pm
are you talking about a cabby, a 2 door or one of the disgusting 4 door variants ?
Last person I knew with a 60mm front drop on a cab lost his sump on a pothole and it cost him a new engine.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Cypriotgeeza
Wed Aug 17, 2011 1:38 pm
mine is a 318is (in my sig pic) yea which is why i was considering a 40mm drop all round..
Stu_Bee
Wed Aug 17, 2011 2:10 pm
I have 70/50 on 16" rims and it's taken about 6 months to wear through the sump. It only catches on narrow country lanes where the middle of the road is high.
oldroydsr4
Wed Aug 17, 2011 4:50 pm
My touring is approx 80mm front 50mm rear on coilovers. The sump sits about 40mm off the road (engine has been lifted for more clearance) , however to avoid any nasty sump incidents I have created a sump guard out of 3mm steel, now I have no concerns.
60mm drop should be no problem at all.
Morat
Wed Aug 17, 2011 5:18 pm
Am I wrong or is the M42 sump lower than the M20?
**BANNED**
Wed Aug 17, 2011 5:21 pm
Morat wrote:Am I wrong or is the M42 sump lower than the M20?
Either way,the advice above regarding a 3mm sump guard should be taken on board!
Youth is wasted on the young.
Wed Aug 17, 2011 5:59 pm
you shouldn't have problems with sump clearance on a 60mm front drop unless you are running on rubber band profile tyres.
Generally though, you are going to start to compromise the ride quality once you go beyond a 40mm drop. A 60 drop defo looks better, but a 40 would leave you with a better feeling car IMO.
I'm on 55 drop at the front and I am changing to a 40 drop as soon as I can be arsed to pull the front struts off.
Wed Aug 17, 2011 6:06 pm
GO GANGSTA RIDER!!!! :mad:
Wed Aug 17, 2011 7:08 pm
its fine if you are aware when driving, certainly won't get stuck anywhere unless you have a big low front spoiler of some sort
A18RPF
Wed Aug 17, 2011 7:25 pm
I have had no problems with a 60/40 drop on my is, except once when having to drive through a huge pothole the width of the road. But if you're careful the sump can be kept out of trouble
asmith88
Wed Aug 17, 2011 7:37 pm
mine is 60/40, and i have had no problems, however i pull up on a kerb at the front of my house, and only just notice that the sump is literally, brushing the moss,
my engine has been lifted slightly as well
1990 brilliant red 318 is
Green
Wed Aug 17, 2011 8:07 pm
I can just fit a can of pepsi under my sump, had two incidents one where I hit a manhole cover that was pretruding the ground. The other when a garage drove it too fast over a brake tester.
Although I've never really had any normal day to day issues, apart from driving on some really poor roads.
Cypriotgeeza
Wed Aug 17, 2011 8:58 pm
thanx for all the advice guys! (especially you Rav! :mad: lol)
hmm i may just go for a 40mm all round for now then if i feel brave enough drop the front some more..
Wed Aug 17, 2011 9:05 pm
Go for 40mm drop and if you want some more at the front you can fit E90 front drop hats and it will bring the front down 15mm whilst still giving a compliant ride
Wed Aug 17, 2011 9:14 pm
Cypriotgeeza wrote: Now on here Ive seen alot of people go for 60F/40R for both looks and handling benefits..
A 'look', of a type, you may get, but there certainly won't be any handling benefits with this kind of crude lowering.
Cypriotgeeza
Thu Aug 18, 2011 7:28 am
haha@ crude lowering
yep i think i have made my mind up of a 40mm drop all around..and e30beemerlad do you know how much them top hats cost? thanx
TDSCHRIS
Thu Aug 18, 2011 7:36 am
I've got a 60/40 drop on my cab with 17" wheels and occassionly if pulling away on lock on and incline rub the arches
Apart from that alls well it's been like it for over two years now without any trouble besides wearing rear tyres
Thu Aug 18, 2011 11:43 am
+1
The 'look' is not considered a good one either, except amongst fellow 'unterhench' types :)
Thu Aug 18, 2011 11:51 am
60/40 with shit dampers, soft springs will be a nightmare, kill your sump in no time and will handle like crap..
bridgemond
Thu Aug 18, 2011 12:23 pm
I had a 40mm drop with shite stock shocks and it was a nightmare. I have a 60mm drop with billy b8's now and it is fine
Cypriotgeeza
Thu Aug 18, 2011 6:53 pm
im apreciating all this advice guys! thanx alot!
ok would anyone mind putting up pics of their prefered lowering style ?
Thu Aug 18, 2011 6:59 pm
What about doing this instead. :D
[youtube][/youtube]
Thu Aug 18, 2011 7:07 pm
"preferred lowering style" is to raise the suspension mounting points in the body, so as to keep the geometry correct. Effectively lowering the body on the chassis.
cypriot_boy_2k7
Thu Aug 18, 2011 7:13 pm
dont do it, ive got 60/40 pillow humps are a no, unless i use them as a full hump
Cypriotgeeza
Thu Aug 18, 2011 7:27 pm
Rav335uk wrote:What about doing this instead. :D
[youtube][/youtube]
hahaha thats exactly what I've been looking for Rav!!
:mad:
Thu Aug 18, 2011 7:30 pm
Choose your different height whenever :cool:
Cypriotgeeza
cypriot_boy_2k7 wrote:dont do it, ive got 60/40 pillow humps are a no, unless i use them as a full hump
yea man im being put off by a 60mm drop on the front after some of these horror stories lol
Cypriotgeeza
Thu Aug 18, 2011 7:32 pm
Rav335uk wrote:Choose your different height whenever :cool:
my thoughts exactly..plus i will look right at home playing Dr Dre and snoop dogg down my highstreet! :cool:
GDBN
Thu Aug 18, 2011 8:00 pm
I had the H&R 60/40 on my cab ... lost my front valance twice and the exhaust used to hit speed bumps. Now have the Eibach 40mm springs and everything is fine.
G
I deserve 6 of the best ...
Cypriotgeeza
Thu Aug 18, 2011 8:06 pm
can you get 40mm eibach springs on their own? I've heard they only come in 35mm
will prob be a choice between them two companies though
DavieP
Fri Aug 19, 2011 8:23 am
I've had a 60/40 H&R cup kit (205.55.15 tyres not rubber bands) on mine for a couple of years now and apart from a minor scrape to the iS lip (caused by going from a very steeply inclined driveway onto the road) I've had no problems at all. OK so I don't go haring over speed humps or aim for pot-holes at speed, but then it's mad to do that anyway. It handles extremely well, there's virtually no compromise in drive quality and it looks just right.
Dave in Torquay
Rtaylor2208
Fri Aug 19, 2011 12:51 pm
Topblag wrote:are you talking about a cabby, a 2 door or one of the disgusting 4 door variants ?
I am now the proud owner of said cab, and have took the ridiculous springs back off and replaced with -30 and even at that its still low but way more drivable.
Cypriotgeeza
Fri Aug 19, 2011 10:54 pm
DavieP wrote:I've had a 60/40 H&R cup kit (205.55.15 tyres not rubber bands) on mine for a couple of years now and apart from a minor scrape to the iS lip (caused by going from a very steeply inclined driveway onto the road) I've had no problems at all. OK so I don't go haring over speed humps or aim for pot-holes at speed, but then it's mad to do that anyway. It handles extremely well, there's virtually no compromise in drive quality and it looks just right.
Hmm not bad! 8) Have you got an IS aswell?
