One major problem with 16" Hartges
Demlotcrew
Post Sat Oct 22, 2005 1:40 pm
The centre caps are plastic and the clips that hold them to the wheel have melted and now rattle badly when fitted! :cry:
Well pissed off!
Andrew
Shinobi1
Post Sat Oct 22, 2005 1:46 pm
Demlotcrew wrote:The centre caps are plastic and the clips that hold them to the wheel have melted and now rattle badly when fitted! :cry:
Well pissed off!
Andrew
mine have never done that ,maybe you get a lot more heat in your braking than me !!! have you tried sicking a bit of masking tape or moulding tape on the wheel to give the tabs something to bite on ?
cheers paul
eko
Old timer
Post Sat Oct 22, 2005 1:49 pm
Sounds strange :mad:Not had any problems with mine either.
Do you have F1 brakes or something :D
alan325i
Post Sat Oct 22, 2005 1:55 pm
if ur generating that much heat,i would check ur calipers are not sticking and heating up ur wheel, would need some serious heat to melt them im sure.
Demlotcrew
Post Sat Oct 22, 2005 2:07 pm
The calipers are fine im sure, ive just been driving really hard recently, and its taken its tole on the Caps.
Some pics;
Dont know if you can make those out, but basicaly both front caps are the exact same, makes me think its the hard driving generaing the heat and melting the caps.
Andrew
Simon
Post Sat Oct 22, 2005 6:05 pm
Could be something to do with that silly 4 banger you got! :twisted:
Martinaston
Post Sat Oct 22, 2005 6:45 pm
Have you ever used acid to clean the wheels ?
The Active 8 stuff does a good job of melting plastic if you dont wash it off.
There is NO nucleus.
orangecurry
Post Sat Oct 22, 2005 6:57 pm
mine are fine too - can't help thinking you've got some problem with the brakes IMHO
Dan318-is
Post Sat Oct 22, 2005 6:58 pm
i dont htink its his brakes
the last time i followed this guy driving he locked up into a BP garage lol
insane drive :thumb:
Demlotcrew
Post Sat Oct 22, 2005 7:18 pm
Simon wrote:Could be something to do with that silly 4 banger you got! :twisted:
Nothing wrong with four cylinders winkeye
Martinaston wrote:Have you ever used acid to clean the wheels ?
Yeah thats totaly true and possible, but i dont use anything but BMWs own wheel cleaners (they are cheap and dont eat through latex gloves)
318is that was an emergency stop! :wink:
Andrew
Dan318-is
Post Sat Oct 22, 2005 7:23 pm
:lol: and a bloody good one at that!
Karan
Post Sat Oct 22, 2005 9:35 pm
its cos u now have a proper engine... and u dont mess about behind the wheel
the amount of stuff that has gone wrong in my engine bay cos of heat and vibration is silly
PeteE30Tourer
Post Sun Oct 23, 2005 10:49 pm
I found the plastic clips break off so easily when putting the hub-caps back on. At least 2 of mine are broken this way now - one to the point that it doesn't stay on the car anymore.
However, i've got some on order with Hartge via Maya Hartge at the moment - 3 for me and 4 for Iain. If anyone wants some replacements, they're about Ԛ£17 each including postage - let me know ASAP and i may be able to add them to my order.
They are on back-order currently and apparently this will be the last batch, so it's a case of buy them now or live without them!
Demlotcrew
Post Mon Oct 24, 2005 12:03 am
Crap! buy now or live without them! Thats why Mini Cooper Works are the better option over the Hartge Minis! Ten-fifteen years down the line you could still get Works bits :evil:
A n d r e w
H35-IAN
Post Mon Oct 24, 2005 12:10 am
andrew m8 tape works a treat!! gaffa tape lol failing that i think theyre 11 pound each from hartge! :wink: hope that helps....ian.
bmw 328i sport e36 :)
orangecurry
Post Mon Oct 24, 2005 9:47 am
I've just rung the Hartge importer for the UK - that's Birds
www.birdsauto.com
(or put in Birds and BMW into a search engine if you don't trust me!)
the genuine caps directly from them WERE cheaper than 17GBP - I ordered and received 4 brand new ones from them last year.
But now Birds do confirm that the caps are on 'back-order', which means there may be some more coming, or there may not (helpful huh?)
Simon
Post Mon Oct 24, 2005 5:00 pm
I also bought a set of centre caps form Birds about 6 months ago, and they were Ԛ£12 each.
PeteE30Tourer
Post Tue Oct 25, 2005 8:04 am
I got a quote from Birds recently for these - they're Ԛ£19+VAT+P&P now. Ended up going through Maya Hartge and ordered some for Ԛ£15+P&P
