Heck spoiler - how do you remove these from bootlid?
Open the boot lid, look under neath the rear lip area and in the holes for the supporting framework of the bootlid you should be able to see white 10mm plastic nuts.
Just undo these with a 10mm socket and the spoiler should come straight off.
if it doesn't then some bandit has probably glued it down with tiger seal, in which case I wish you good luck
