Further more the guys car control was epic which made the experience even better, and now I can't wait to m52 mine! The exact setup as was in his car is what I'm putting in mine, bring it on
Nice1 for that mate, you know who you are
About 300cc and an alloy block.Kieran_n22 wrote:Silly question but what is the difference in the 2?
e30-dk wrote:...............The m52 makes for a proper fast e30, not just that,, a proper fast car full stop 8)
Plus M52 2.8s have the option to upgrade to an M50 inlet manifold and BBTB.bss325i wrote:About 300cc and an alloy block.Kieran_n22 wrote:Silly question but what is the difference in the 2?
Early M50's dont have vanos either.
which actually fits in bloody well with what i've just posted.e30-dk wrote:My old high comp m20 2.5 was showing me 140mph, that's with 170bhp![]()
I do see your argument though, obv the flat face of the e30 would suffer at the top but with a clear 40 odd bhp more and shitloads more torque it could well be possible
George wrote:Incidentally out of interest, for an M52 engine swap in the E30, how many hours are required (ballpark)?
I was with you right up to here...harry_p wrote:2.01x 134 = 281bhp
How much power can you get from a M52 with the M50 2.5 manifold? Bhp and torque How mcuh would you be spending on parts for the conversion? How hard is it to fit?e30-dk wrote:If you mean m50 and m52......
M50 is an iron blocked 2.5
M52 is an ally blocked 2.8
But by putting the m50 2.5 inlet manifold on the m52 it unlocks hidden horses and opens it right up.
I was told by danthe that people think there isn't much difference between the m50 and m52 but tonight I've seen for myself its a big difference!! The m52 makes for a proper fast e30, not just that,, a proper fast car full stop
cecotto479 wrote:George wrote:Incidentally out of interest, for an M52 engine swap in the E30, how many hours are required (ballpark)?![]()
I still have your address and phone number.
I've seen a GPS indicated 140mph in mine with an E30 325 box and 3.73 diff. Although there was still some revs left it may have reached 145-150, I think a true 165 is highly unlikey.DanThe wrote:My 2.8 build would pull me uphill very quickly and easily to just over an indicated 150mph where it would hit the rev limiter, 6500rpm, this is with a 3.25:1 diff 1:1 5th gear and 15 inch BBS wheels. Due to the classic E30 speedo over read this would be more like 140mph.
The 3.25 diff and E36 box is near enough the same gearing as using an iS box and 3.91 diff.
Even with a 3.64 diff and iS overdrive box there is no way a GPS signal would be more than a fraction over 150mph with the engine on the rev limiter, with another 500rpm (7000rpm rev limit) you would get an extra 10mph
The m50 will outperform a standard 325i sport, more bhp and more valves.polsta wrote:sounds awsome !!
also what sort of prices are the 2 engines/set ups and all required gear needed ? (ie a rough figure for the 50, and the 52)
after seeing a lot of these sort of cars of late, i have pondered instead of a hard tech 1 sport hunt, if maybe a project like looking for a very nice solid 2 door base like a lovely 320se or something that was a minter shell wise, and doing an engine conversion , then the kit and interior might be a way to go in the future , just wondering if it would wind up cheaper or more expensive than a sport,or not
also is the m50 faster than a 325i sport ? or the same roughly ?
nice onme mate thats helped clear it up, so when quoted up to £2000- is that for the engine, all bits, and the putting it all in too / or just all the parts ?ETERNITY wrote:The m50 will outperform a standard 325i sport, more bhp and more valves.polsta wrote:sounds awsome !!
A healthy m20 can be fun and a pleasure to drive, but its performance is suttle compared to an m50 and m52.
When I enquired about an m50/m52 conversion I got qouted from £1300-£2000 done properly.
If your after a fast road e30 the m52 is the best way to go.
A good shell will cost you 1k, conversion costs 2k, styling and bodywork/alloys 1k, 1k for suspension setup and that will bring you up to 5k. A real good sport will cost you 4-5k and probably more in the next 3+ years.
But then if you have a custom made e30 to your requiremnets and it will be more fun than any sport.
The resale value will be less than a good sport, because it wont be factory spec.
So you have to figure out if its a good fun e30 you want which will give you driving pleasure everytime you drive it or just a (sport label) that will hold its value.
Personally I would buy a good shell and build it to my requirements, and not bother about resale value.
I have bought a sport, and am restoring it slowly. Its great to drive and I know the value will keep. But next time I am going to buy a shell and do an conversion, and set up the suspension and car to my requirements and not bother thinking about resale value, because it will be invidual to me.
I hope that gives you clairity on the subject
ryan0143 wrote:lol yeah i will probs go M52 one day, but M50 will suffice for now,
is an M50 E30 sort of civic type r etc quick?
i must say i cannot wait for some 6 pot power.
It will add a bit to both, but will make more difference to the way it accelerates than to the top speed. It's a good mod to free up restricted power, and helps with feel and response as well as on paper figures.TheHeap wrote:We have a 328i auto and it shows 150mph clock speed quite easily. What will fitting a 325i inlet manifold actually do?
Top end?
Acceleration?
