Fitting Cruise Control
cee
Wed Apr 13, 2011 10:47 pm
Can it be fitted to any model? And is there a decent guide anywhere?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
mark_i
Wed Apr 13, 2011 10:56 pm
Yes, this is a good e30 toy, esp. for automatics.
For a manual, make sure you get the clutch switch.
Also if the get the kit from a LHD, (US or Germany) you will have to modify the loom to fit a RHD
cee
Wed Apr 13, 2011 10:59 pm
Thanks.
Will a kit from any e30 fit any other? i.e. could I get a 325 kit and stick it on my 318iS?
Will be doing a lot of motorway mileage come September so will definitely be worth it,
mark_i
Wed Apr 13, 2011 11:15 pm
need to double check that.
The M42 TB has a different alignment to an M20, so the Bowden cable may not fit...
I will be down the garage later and confirm
cee
Wed Apr 13, 2011 11:17 pm
If not is there a kit that will fit? Doesn't have to be from a 325 (it was just an example)
charlE30
Thu Apr 14, 2011 5:34 am
Original BMW E30 cruise control can be fitted across the range you'll just need an alternative bowden cable on your 318is, I'm sure I've heard of using an E36 cable on the E30 C/C actuator but you may be able to use the original. IIRC it was an option on all E30's but can't see it listed for the 318is?
Hopefully Mark will come back saying it'll fit straight on :)
If you do any miles it's a great extra to have especially on the motorway
BMW F31 335d xdrive
DaveD
E30Zone Wiki Specialist
Thu Apr 14, 2011 5:12 pm
just posted this in the wiki..it tells all...mind you someone will say it doesnt...it might even tempt me to fit the one I have lurking :D
http://www.e30zone.net/e30zonewiki/inde ... rol_instal
cee
Thu Apr 14, 2011 6:20 pm
Thanks!
mce30
Thu Apr 14, 2011 6:30 pm
Bmws EBA on cruise control http://www.ow.no/archive/eba/764.PDF
Thu Apr 14, 2011 7:24 pm
when i looked into fitting it to my IS, i discoverd that the 318is was never avalible new with cruise, so you need a few e36 m42 cruise control bits for the throttle housing etc iirc.
cee
Thu Apr 14, 2011 7:51 pm
Did you get around to fitting it? If so do you have a parts list?
Thu Apr 14, 2011 7:55 pm
i didnt, i think i found most the info i needed on m42 club :)
cee
Thu Apr 14, 2011 7:57 pm
Ta
mark_i
Thu Apr 14, 2011 8:44 pm
Apologies.
I couldn't get in to the lock-up today for a pic of the M20 cruise cable.
Seems like you got the info already.
The key is to get the correct Bowden cable that works with the M42 throttle body.
cee
Thu Apr 14, 2011 8:47 pm
Thanks for the info and thanks for trying.
polsta
Thu Apr 14, 2011 9:07 pm
want to fit cruise control myself to my is, where do you get the correct bowden cable from ? /know whats the correct one ?
also i was wondering- how is the cruise control engaged/diss engaged once fitted in an e30 ? (ive never driven a car with cruise control) , still need to get it fixed in my discovery
cee
Thu Apr 14, 2011 10:28 pm
An additional stalk
polsta
Fri Apr 15, 2011 6:50 pm
what side does it go on ?
sorry for sounding cluess,but ive never driven with cc
so your driving along at 70 on motorway, think cc....do you just flick the stalk up/on , and it cuts in and will just cruise constant at that speed ? i just wonderd as i havce no idea, if you break or slow down/push clutch in or anything, will it automaticly turn off or only when you move the lever back ?
cee
Fri Apr 15, 2011 6:57 pm
It will stay switched on at the set speed (it's not adaptive CC) and will cancel if you hit the gas or breaks
charlE30
Fri Apr 15, 2011 7:05 pm
polsta wrote:what side does it go on ?
There are two versions, the later has accelerate & deccelerate on the stalk which is really useful for adjusting your speed while it's on. The stalk is fitted to the left of the steering column below the wiper stalk vvvv (not the best photo but you get the idea)
To set it just flick the stalk up and it holds whatever speed your at (30mph and above) When fitted properly there is both a brake switch and a clutch switch (manual only) so that if you touch the brakes or clutch it disengages the CC. You can also turn it off by flicking the stalk down.
Charlie
BMW F31 335d xdrive
cee
Fri Apr 15, 2011 7:10 pm
Your photo shows it on the right...?
**BANNED**
Modern systems are somewhat different to the type that was fitted to E30.
In general,you drive up to the speed you wish to travel at,engage the thing and take your tootsies off the pedals.You can then vary your speed by raising or lowering the set speed with the cruise control.Touching the brake or clutch pedals will disengage the system,you can then 'resume' the set speed by operating the control.
I use cruise whenever possible whilst working,saves me the effort of holding the gas pedal at the truck's limited speed,this is one reason why us truck drivers hate car drivers who overtake us and then slow down..... winkeye
Youth is wasted on the young.
cee
Fri Apr 15, 2011 7:12 pm
So if you have it set so say 70, and hit the brakes, then reactivate, will it automatically accelerate back to 70?
**BANNED**
Fri Apr 15, 2011 7:17 pm
cee wrote:So if you have it set so say 70, and hit the brakes, then reactivate, will it automatically accelerate back to 70?
That's right!
The modern Mercedes trucks I drive whilst working are even cleverer than that,I can come off a roundabout 3 or 4 gears down the 'box,engage cruise,and change gear without touching the throttle,the electronic's take care of the engine speed matching for me,going up hill with cruise engaged,it even blips the throttle!
Dead easy,hardest part of my job,where I earn my pay,is reversing the thing accurately onto a loading bay.
charlE30
Fri Apr 15, 2011 7:18 pm
Yep and it's a wierd feeling as you feel the accelerator pedal move on it's own, made me jump the first time :D
edit **I must learn to type quicker LOL**
BMW F31 335d xdrive
Fri Apr 15, 2011 8:09 pm
cee wrote:It will stay switched on at the set speed (it's not adaptive CC) and will cancel if you hit the gas or breaks
Not so.
If you accelerate the let off so the speed drops, it will continue to hold the speed it was set at.
**BANNED**
Fri Apr 15, 2011 8:10 pm
Modern,'fly by wire' systems,you do not feel the pedal move!
mark_i
Fri Apr 15, 2011 9:50 pm
Just to confirm...
The M20 actuator and Bowden cable have a square lug to hold the cable in place on the TB. Also the Bowden cable cannot be removed :(
This will not fit the M42 TB which has a round securing lug.
The later e36 cruise actuator will work with an e30 318is, just got to modify the electrical connector.
Let me know if you want any photos.
polsta
Sat Apr 16, 2011 3:19 am
ok thanks for the replies i get it, and sounds like it would be nice to have
so what bits exactly will i need to look for for a 318is ? are the stalks all the same or 2 different types as per the reply saying there are 2 different versions ?
charlE30
Sat Apr 16, 2011 8:47 am
polsta wrote:ok thanks for the replies i get it, and sounds like it would be nice to have
There are two different versions the early which is a basic cruise on, cruise off with resume speed IIRC and the later which has these functions but also has the option to accelerate and deccelerate. Both versions will fit all E30's but will need the acuators bowden cable modded to work with the 318is.
People have in the past done this, have you been on that M42club or similiar website? the answer will be on there.
Just found it http://www.m42club.com/forums/
BMW F31 335d xdrive
